Front Rotor Corrosion
Old Apr 7, 2017 | 01:52 PM
blackhorse21's Avatar
Hi everyone. It is me again with a different question. Please check the pics for my 03 TLs front rotor. Are the white scratches on the brake rotor indicate a corrosion problem? I got the car 1.5 yeas ago and just change the brake pads 8 months ago. No loss of brake force as I can tell. Let me know your suggestions. Thank you!
Driver side, front rotor
Passenger side, front rotor
Old Apr 7, 2017 | 02:12 PM
TacoBello's Avatar
You're fine, man. I wouldn't worry about it.
plus, brakes work on the basis of friction. Just burn that shit off. Drive fast, brake hard. As long as it isn't a grease or lube of any kind that would cause your brakes to lose gripping forces, I'd just burn it off.
There could also be something on your pads, or the composition of your pads that are leaving streaks. 99% chance it's fine.
Old Apr 7, 2017 | 02:49 PM
Thank you! Just got worried for corrosion
Old Apr 7, 2017 | 03:29 PM
MBP 03's Avatar
When you changed the pads, did you have the rotors cut or install new ones? That looks like an awful lot of corrosion on the rotor hat and edge of the rotor for something only 8 months old.
As far as the braking surface goes, I wouldn't worry too much about those little specks.
Old Apr 7, 2017 | 04:02 PM
Sorry for the confusion. The rotors are old ones from the previous owners. I was told that these rotors has good enough surfaces last time. So just changed the pads. Ohio has very bad snowing winter. The side or the rote is always looks awful since the first day I see it. Should I do anything?
Old Apr 7, 2017 | 04:55 PM
MBP 03's Avatar
Since the new pads already wore into any grooves in the rotors by now, unless the rotors are warped and you feel any pulsation or vibrations while braking, I wouldn't do anything at this point.
Old Apr 7, 2017 | 05:04 PM
TacoBello's Avatar
When just changing pads, technically you're supposed to get the rotors resurfaced if you're using the same ones. But it's a littl too late for that now. As mentioned, I really wouldn't do anything about it now.
Old Apr 7, 2017 | 07:34 PM
Thank you all for the suggestion. I will keep my eye on this.
AtlM5
Jan 25, 2017 03:54 PM
srg818
3G TL Photograph Gallery
21
Dec 10, 2016 09:00 PM
smurfhunter
Oct 15, 2016 03:50 PM
RDXMac
Oct 13, 2016 07:12 PM
