Front Hub
Front Hub
I got a diagnosis done on my car, and they mentioned I also needed a wheel bearing and hub replaced on the right front. I got a print out from AllData, seems easy enough. I'd have to take it to a shop to get the hub pressed out though. Anyone have experience with this? How long would it take a moderately skilled DIY'r?
My biggest problem right now, no one sells the front hub! Not Napa, Autozone, O'Reilly's.... What's up with that, Aucra parts only???
you need the actual wheel bearing- not the cv avle bearing assembly?
did you ck our diy section?
https://acurazine.com/forums/2g-tl-1999-2003-98/new-official-2nd-gen-tl-diy-thread-706083/
Where did you find it online? I have a 99.
I was told at the local Napa/machine shop that it's possible the shop quoted replacing it because they didn't want to mess around with it.. just use new parts... IDK I didn't want to tear it appart, and need it... And have the car waiting for a part.
Some possibilities; on lots of cars the front wheel bearing is serviced as a "hub and bearing assembly". So it might be a terminology problem. Another; it's easier to do the job if you don't have to pull the inner race off the old hub. Lastly, the bearing can spin on the hub and ruin it. I've never seen this on a honda, usually ford products, but they might be "diapering". [covering their ass ahead of time]
I have taken a knuckle (from a different car) to my local Napa. They removed the old bearing & reinstalled the new one.
www.acuraoemparts.com - Approx. $46 for a '99. Did you search online?
The shop probably didnt know that on this car the bearing and hub are not one piece like many cars. There is no reason to replace the hub. Buy the bearing, have a shop press out the old bearing from the knuckle and hub and press the new one on.
jmoney2001
Sep 11, 2015 12:07 PM
