Few problems after battery disconnect.
03 TL-S.
After disconnecting the battery to reset ECU, nothing else was changed.
Now my "auto" roll down and up window for drivers side doesnt work.
Also, when attempting to move my drivers side window via the controls on the drivers door, it no longer works, actually, If i press down or left, nothing happens, but if i press down, window moves right, if I press right, it moves right, just faster than pressing down.
Both of these "features" worked perfectly prior to the disconnect of the battery.
Any ideas?
Any ideas?
USDM -> JDM
I've had the problem with the auto roll down and up with my car when I disconnected my battery. All you have to do is push the button all the way down to roll the window down and hold the button until the window is all the way down, and then roll the window up about half way then push the auto button all the way back down then try to roll the window all the way up and then push the auto button to see if the "auto" works. i've had this happen to me about 3 times and was able to fix it by doing it. It took awhile but it will eventually work again.
It's the Halladay season!
For the auto up/down, it has to "re-learn" the window positions. Hold the buttons ALL the way down until the window is down, and keep holding for a few seconds. Then repeat going up. It should work after it learns that.
As for the mirrors, that is pretty weird. I would take the door panel off and check the connection at the switch.
i had a similar problem after my battery was disconnected...only now not only do my mirrors act weird, but the memo buttons for my seats don't work, and the dimming light no longer comes on when i open the doors/unlock the car. i realize that could just be a blown bulb, but its a little coincidental..
MechEng
my memory seats stopped working as well after disconnecting the battery during my sub and amp install but i was able to fix my auto up/down windows. i checked all fuses and everything. no idea what happened.
HeloDown
09-08-2015 06:51 PM
