Extra bolt after timing belt replacement -where does it go?
Old May 5, 2019 | 01:48 PM
efair's Avatar
3rd Gear
Hi, new member here, with a somewhat embarrassing first post. I helped my SIL change his timing belt yesterday, and despite our best effort to keep up with things chronologically we ended up with one extra bolt near the end of reassembly
with no idea where it goes. It requires an 8mm socket. Any ideas?
Old May 5, 2019 | 02:09 PM
Could it be part of the alternator auto-tensioner?
#17 on the link below:
https://www.acuraoemparts.com/auto-p...r-bracket-scat
Old May 5, 2019 | 02:55 PM
efair's Avatar
3rd Gear
I bet you're right, thank you. IIRC we had to grind down our socket to get it out.
Old May 5, 2019 | 03:06 PM
That's the first thing that came to mind when looking at the picture.
It's not hard to over look, the other two shorter bolts are probably what's holding it (auto tensioner assembly) on now.
Old May 5, 2019 | 05:49 PM
efair's Avatar
3rd Gear
Correct - third bolt securing the serpentine tensioner, back in place now. (did I say thanks?) I'm puzzled what role this bolt plays since it's A) smaller diameter and B) much greater length than the other two (which seem adequate to secure the tensioner in place).
Old May 5, 2019 | 06:17 PM
My best guess is that the auto tensioner is supposed to place a safe amount of engineered pressure, against the alt. belt at all engine rpm's, to adequately keep the belt stable/tight through said various rpms.
The middle bolt, the one in your picture, is (6X60) and adds extra clamping force along with the other two short one's (6X25) to keep that device in place while it applies force. As you can see from the picture below, the longer one goes in the middle of the triple bolt fastener pattern with the two short one's on the outside. The last thing anyone needs is that auto tensioner to disconnect/loosen significantly at highway speeds.
Originally Posted by Skirmich
el.profe
Feb 20, 2020 06:26 PM
MarkF786
Oct 31, 2018 07:03 PM
ak9210
Jun 13, 2014 10:14 PM
kaushiknair
May 15, 2013 02:44 PM
Miamicarfan
Dec 24, 2012 04:54 PM
