ENGINE TEMP issues!
Old Aug 2, 2006 | 10:40 PM
TL.00.3.2's Avatar
Angry ENGINE TEMP issues!
What's good fellow tler's? I have an issue with all this hot whether and the temperatue of my engine. I am not talking about the outside temp, i'm talking about the actual engine temp. When i have my car stopped @ a stop light with the AC on the needle heads up sky high. It literally goes as high as the last notch before the red. I drive a little bit and temp comes down somewhat, the reading is still at 3/4. Come to another stop and temp rises near 2 the red again. There is ample radiator fluid and fan comes on but the engine still runs red hot. Any suggestions? Maybe the thermostat? any info would help, THANKS
Old Aug 2, 2006 | 11:46 PM
jonjacob's Avatar
im guessing thermostat.
Old Aug 3, 2006 | 01:40 AM
tim'sTLS's Avatar
Check the radiator for gunk/calcium buildup by opening the radiator cap(whiteish/rusty). Verify that both fans run.If all those check out. Replace the Thermostat. Test drive.
Old Aug 3, 2006 | 08:49 AM
phipark's Avatar
Not Asian
Replace the thermostat and bleed the coolant. It could also just be air in the coolant. Make sure you get this fixed ASAP to avoid busting a head gasket. If it's still not fixed, you may need a new water pump.
Old Aug 3, 2006 | 09:25 AM
TL.00.3.2's Avatar
Much thanks.
Thanks for the input guys. I'll take a closer look today. Keep the suggestions rolling, dont want a blown gasket or any engine damage so let me know everything.
Old Aug 3, 2006 | 12:17 PM
bkzjimmy's Avatar
NiGhT rIdEr
it most likely the Thermostat like everyone else said. check to see if ya fans are coming on.
Old Aug 3, 2006 | 01:09 PM
acurabum's Avatar
Put your cabine air temp. to RED ( heat ) if it 's not blowing hot
air = thermostat stucked and does not open ......
Old Aug 5, 2006 | 05:51 AM
ssaxman's Avatar
check that the hose in the reserve tank is actually drawing antifreeze if not check all of the above asap !!!!!
01CLOwner
Oct 9, 2015 01:07 PM
BigJilm
Sep 21, 2015 08:32 PM
carz0159
Sep 20, 2015 06:11 PM
whitesoxsfan12
Sep 7, 2015 04:07 PM
NSolace
Sep 3, 2015 08:02 PM
