Engine Starting problem
Old Oct 1, 2013 | 05:15 AM
luki2604's Avatar
Unhappy Engine Starting problem
hello,
I have a problem with my acura 3,2tl 1999.
When I'm starting cold engine, I have to turning 4-5sec before it starts. There is no problem to start with warm engine.
When starts ( cold or warm ), RPM ranges is between 400-700 and sometimes engine turns off.
PS. I need to add, a few days ago I had an incident: a coolant leak, so the temperature was in red marker for about 5-10 minutes of drive. After I saw it, I stoped the car, waited about 15 minuts, repeaired leak and refilled a coolant fluid. After that everything was ok for 1-2 weeks. Engine Power is ok, temperature is ok.
What could be the reason? I don't know, check compression ? check valves? what else? Please, help me what to do ?
Best regards, Luk.
Old Oct 1, 2013 | 05:20 AM
luki2604's Avatar
ps. I forgot to add, that sometimes ( 1/5) everything is OK. Acura starts normaly, RPM is OK...
OBD2 shows no any problems.ps. I forgoted to add, that sometimes everything is OK. Acura starts normaly, RPM is OK...
Old Oct 1, 2013 | 07:13 AM
luki2604's Avatar
I checked jusy DTC, I have a P1457 DTC code.
Old Oct 5, 2013 | 08:45 PM
3.2TLc's Avatar
Welcome Luki2604 !!!
Check out the 2nd gen DIY's. The EGR passageways may need cleaned. Try some fuel system cleaner. Ya may want to consider having the cooling system pressure checked for leaks. The 1457 code indicates an EVAP problem. Reset and see if it comes back.
Old Oct 18, 2013 | 12:58 PM
luki2604's Avatar
hey,
stil P1457.
It is normal clicking all the time?
I tested this clicking valve like in Manual, seems to be ok.
Old Oct 18, 2013 | 06:15 PM
3.2TLc's Avatar
P1457 indicates that a leak has been detected in the EVAP control system.
The clicking that you hear is from a sticky "Purge Control Solenoid Valve". A common issue normally resolved by replacing the valve unit.
Old Oct 18, 2013 | 09:22 PM
luki2604's Avatar
OK, but when I plugged the power supply 12V directly to the valve, then it works normally- without clicking- just one click to OPEN the valve or one to CLOSE the valve.
So it makes sense to repleace it?
PS. wires ro PCM are OK.
ninersfgiantsfan
Sep 9, 2015 01:14 PM
HeloDown
Sep 8, 2015 06:51 PM
jordanboi
Sep 5, 2015 01:33 AM
chrisr
5G TLX Problems & Fixes
Aug 31, 2015 08:24 PM
Stu2414
4G TL Problems & Fixes
Aug 30, 2015 07:30 PM
