engine shuts off while driving *scary*
Old Dec 23, 2008 | 02:02 PM
ch0wch0w's Avatar
Im driving on a freeway at nite... and all of sudden i notice my odometer was dropping and so was my gas meter. The lights inside my car turned off and the car began to decelerate by itself. A few seconds after this, my car turned by on with the gas meter and odometer went back to normal and i could accelerate. Other times when this happen. I came to a complete stop and was on "D" drive so I had to start my car again on "P" pakring when the engine shutted off. What is wrong with my car? Im thinking sparks or ignition?
Old Dec 23, 2008 | 02:13 PM
ch0wch0w's Avatar
btw i drive a 1999 acura TL .. stock
Old Dec 23, 2008 | 02:48 PM
Bob_F's Avatar
My guess is that your ignition switch is failing.
There was recall for the 1999 TL ignition switch and even the replacement switches are known to fail.
My 1999 TL is on its third ignition switch. I had similar symptoms with a loss in power along with the dash needles dropping towards zero. I also had low speed engine stalls along with starting problems.
If your switch has not been replaced under the recall, Acura will install a new one for free. If it has been replaced, you can install one yourself for about $50.
Here's a great DIY thread with photos that was posted by forum member 6MTUA5:
https://acurazine.com/forums/2g-tl-1999-2003-98/diy-99-tl-ignition-switch-686000/
Old Dec 23, 2008 | 07:10 PM
Rajca's Avatar
wham bam thank you ma'am
x2 ignition switch
Old Dec 23, 2008 | 07:26 PM
01tl4tl's Avatar
well 3 makes it an official guess right?!
you need an ignition switch
register and see if it was ever done under recall
if it was, just buy another and install
http://owners.acura.com/registration...erstepone.aspx
Old Dec 23, 2008 | 08:56 PM
6MTUA5's Avatar
No He Can't
I'll make it 4
Get it replaced soon. Order it online from www.acuraautomotiveparts.org and use my DIY
Old Dec 25, 2008 | 02:58 AM
thinhthan's Avatar
yea its most like your ignition switch mines does the same thing i still need to order a new one
Old Dec 25, 2008 | 10:13 AM
01tl4tl's Avatar
cmon thin- we want you to stick around~
- get the switch replaced before the car stalls in front of a big rig while you are getting on the freeway~
50 bucks for your safety/life,,, mom might even give you the money!
Old Dec 26, 2008 | 05:19 AM
YeuEmMaiMai's Avatar
yeah check the switch and you will most likely find it is toast. common problem for a lot of cars expecially FORD and HONDA........
Old Dec 30, 2008 | 11:06 AM
hiply's Avatar
Driving last night and engine dies out
I was driving last night and the engine died out. I had this problem before where I was driving on the freeway and the power would go out and all of the sudden come back on and everything was fine, but last night was the first time where it went completely dead. Possibly the ignition switch?
Old Dec 30, 2008 | 11:10 AM
01tl4tl's Avatar
thats the very first thing to check if its a 99-
plus check if the recall install of a switch was done- you can call acura
1-800-382-2238x5 with your vin and they can tell you
also happens to other years when you have a bunch of keys on the ring
Old Dec 30, 2008 | 11:11 AM
01tl4tl's Avatar
on the 99s, having it replaced before.. does not mean it wont fail again
peti1212
ILX
22
Jan 5, 2022 05:14 PM
Soul_Deamon
4G TL Problems & Fixes
Nov 2, 2015 04:32 PM
HeloDown
Sep 8, 2015 06:51 PM
bryan zaragoza
Sep 8, 2015 12:28 AM
Stu2414
Aug 30, 2015 07:30 PM
