Engine Mounts...
Old Apr 12, 2006 | 11:43 PM
chabooky's Avatar
--BASS FANATIC--
Engine Mounts...
So yeah all 3 of em on my 2001 Acura TL are busted... would that be the reason my car gives a jerk at the step of my aceleration...? anybody wanna refer to a place where i can get those engine mounts for a good price?
Thanks guys...!!!
Old Apr 13, 2006 | 08:09 AM
NSXNEXT's Avatar
www.acuraautomotiveparts.org
Old Apr 13, 2006 | 05:34 PM
chabooky's Avatar
--BASS FANATIC--
Thanks for the link... I can't really seem to know what I need so many part numbers and I cant tell my left from my rights. -scratches head-
Old Apr 16, 2006 | 09:39 PM
Trojanman750's Avatar
i just shelled out 240$ bucks for the engine mounts from that same website...gotta get em installed soon
Old Apr 17, 2006 | 10:09 AM
chabooky's Avatar
--BASS FANATIC--
really how many mounts did you get?
Old Apr 18, 2006 | 11:02 PM
s0ldiA's Avatar
5th Gear
I installed the front mount myself on my 03 TL-S, it was easy.
Old Apr 19, 2006 | 01:31 PM
acutee's Avatar
How did you pull the old one out? I had to feed it through the top.
Old Apr 19, 2006 | 02:46 PM
fsttyms1's Avatar
well it cant go down unless you remove the front subframe.
Old Apr 19, 2006 | 04:43 PM
chabooky's Avatar
--BASS FANATIC--
how many?
Old Apr 20, 2006 | 10:22 AM
acutee's Avatar
There are 4 of them, but normally people replace the front, the right, and the rear. I hardly hear anyone mentioned about the left mount (drivers side). The front and the right are easy enough to do. For the rear I would suggest to bring it to the shop if you have no idea how to do it.
Old Apr 20, 2006 | 12:31 PM
fsttyms1's Avatar
Almost correct. There are 5 of them. 2 are on the left side
Old Apr 20, 2006 | 03:07 PM
acutee's Avatar
Sorry about that, and thanks for the correction.
Old Apr 20, 2006 | 04:34 PM
chabooky's Avatar
--BASS FANATIC--
=) thanks again guys
Old Apr 21, 2006 | 12:27 AM
whatwasthat's Avatar
how easy is it? i need my passenger side replaced..
Old Apr 21, 2006 | 12:40 AM
fixedtl's Avatar
how can you tell the mounts went bad?
Old Apr 21, 2006 | 11:11 AM
s0ldiA's Avatar
5th Gear
The easiest way to see a bad mount is to have someone put the car in gear, with the brake on ofcourse. While in gear push the gas just a bit and watch the movement of the enigine. I would start off with reverse then go to drive. Try that, but be very careful not to shift while the engine is not idling.
Old Apr 21, 2006 | 11:15 AM
i can hear a clunking noise when i go over bumps plus the dealer confirmed it when i brought my Tl in to have my OPDS replaced.
Old Apr 21, 2006 | 12:31 PM
fsttyms1's Avatar
Passenger side is a breeze. 20 min tops
Old Apr 21, 2006 | 12:35 PM
georgy_d28's Avatar
OPDS? i thought that was for the side airbags
SidhuSaaB
May 30, 2020 12:40 AM
BIGxRED
Oct 19, 2015 10:47 PM
joflewbyu2
Oct 8, 2015 11:16 AM
ROSSARONIE
Oct 2, 2015 11:46 AM
STL TL-S
Sep 23, 2015 08:52 PM
