Engine Mounts...
--BASS FANATIC--
Engine Mounts...
So yeah all 3 of em on my 2001 Acura TL are busted... would that be the reason my car gives a jerk at the step of my aceleration...? anybody wanna refer to a place where i can get those engine mounts for a good price?
Thanks guys...!!!
Thanks guys...!!!
--BASS FANATIC--
Thanks for the link... I can't really seem to know what I need so many part numbers and I cant tell my left from my rights. -scratches head-
well it cant go down unless you remove the front subframe.
There are 4 of them, but normally people replace the front, the right, and the rear. I hardly hear anyone mentioned about the left mount (drivers side). The front and the right are easy enough to do. For the rear I would suggest to bring it to the shop if you have no idea how to do it.
The easiest way to see a bad mount is to have someone put the car in gear, with the brake on ofcourse. While in gear push the gas just a bit and watch the movement of the enigine. I would start off with reverse then go to drive. Try that, but be very careful not to shift while the engine is not idling.
Originally Posted by fixedtl
how can you tell the mounts went bad?
i can hear a clunking noise when i go over bumps plus the dealer confirmed it when i brought my Tl in to have my OPDS replaced.
Passenger side is a breeze. 20 min tops
SidhuSaaB
05-30-2020 12:40 AM
joflewbyu2
10-08-2015 11:16 AM
STL TL-S
09-23-2015 08:52 PM
