engine mount issue
Old Jul 10, 2011 | 11:24 PM
TLboss's Avatar
engine mount issue
replaced my front and side engine mounts today on my 02 tl-s. somehow im still getting vibration when i put it in drive as well as during acceleration usually in 2nd gear at around 2k rpm. i connected the vacuum hose firmly to the new front mount. what else could it be?
Old Jul 11, 2011 | 10:35 AM
01tl4tl's Avatar
ck rear mount- its also vac boosted
ck the cv axle bearings- those will cause vibration on accelleration- iirc the inner one causes that
but you always replace the entire assembly for ease and cost
get a NEW not rebuilt assembly if needed- try NAPA they have a known good supplier
is there a torn boot on any of those--4 to ck
that = part death
fsttyms1's Avatar
Rear mount or trans mounts.
Old Jul 12, 2011 | 07:53 PM
TLboss's Avatar
ok i ordered the rear mount. could it also be the engine mount solenoid valve that 2 hoses run to? one from the mounts and another from the back of the intake manifold
Old Jul 12, 2011 | 08:12 PM
my.daily'tl''s Avatar
Always Working In
if you have vac gauges you can check that
Old Jul 13, 2011 | 06:15 PM
TLboss's Avatar
where would i hook the gauge up to the solenoid valve or the hose that runs to the mounts?
Old Jul 13, 2011 | 08:01 PM
Always Working In
straight out of the service manual. here ya go!
Old Jul 14, 2011 | 07:47 PM
TLboss's Avatar
thanks for help, i did the test with the vacuum and looks like the rear mount is not holding vacuum so ill replace it along with the solenoid. going to do a bunch of work on the car this weekend -rear engine mount, front lower ball joints, new sway bars and end links, control arms and all the bushings up front
Old Jul 14, 2011 | 09:10 PM
Karanx7's Avatar
Unregistered Member
Try not to quote posts with big/lots of pics. It just takes up space unnecessarily.
drone619
Jan 26, 2016 07:09 PM
BKSleeper
Oct 7, 2015 10:20 AM
Aging-Hacker
Oct 5, 2015 11:44 AM
sockr1
Oct 1, 2015 01:31 AM
whitesoxsfan12
Sep 7, 2015 04:07 PM
