Electronics problem after ECU reset?
Old Jul 31, 2009 | 12:12 PM
SYLKIE's Avatar
Wye-Ey-Fore Sicks-Spd
Question Electronics problem after ECU reset?
So yesterday i finished installing my thermoblocs, and thought it would be a good idea to reset the ECU, considering the thermoblocs were the last in a list of other mods i've done recently. everything went fine, i reset the ECU, reconnected battery, punched in the radio code and everything was cool. but when i went to roll down drivers side window, the auto-roll down feature or whatever wouldn't work. you know, when you press the drivers side window switch down to the second click, it will roll the window all the way down by itself. i know this isn't a huge deal, but i'd still ike to know whats going on. any ideas?
Old Jul 31, 2009 | 02:21 PM
hANDYcaptd's Avatar
It's the Halladay season!
That's normal. It has to re-learn the auto up/down. After you use it a couple of times, it should work again.
Old Jul 31, 2009 | 02:46 PM
fsttyms1's Avatar
The relearn is in your manual on how to reset it.
For those that are reading impaired.. Push and hold the window down and keep it held down for a few seconds after its down all the way, repeat for up. It should now work.
Old Aug 1, 2009 | 02:43 PM
SYLKIE's Avatar
cool, thanx. it stopped now. i was just confused about tho. it seems like a really wierd electronic hiccup to have.
Old Aug 1, 2009 | 02:48 PM
SYLKIE's Avatar
fsttyms1: another thing you might know about, or anyone else, is when i'm cruising on the highway or main road in 4th gear i believe, and i let off the gas, there's a small thud, and then again when i reapply gas. my assumption is that this just the torque converter locking up. please tell me that i'm right and my tranny isn't showing the first signs of failure!!
Old Aug 1, 2009 | 03:00 PM
fsttyms1's Avatar
Its not a hiccup. When you disconnect the battery you reset the system. You have to have the system RE-Learn.
Old Aug 2, 2009 | 12:29 AM
uhg0's Avatar
This Re-Learn thing is only for the driver's window? or there are more devices that need to reLearn something? I have resetted it several times and the auto-down always works fine the first time I want to lower the window.
Old Aug 2, 2009 | 08:29 AM
fsttyms1's Avatar
02 and 03 have the auto up feature which require a relearn. The 99-01 dont have to do that with the auto down only feature.
Old Aug 3, 2009 | 10:07 AM
mlassek's Avatar
check your engine mounts
Old Aug 13, 2009 | 10:12 AM
FlacoJ's Avatar
i think he's right i disconnected my battery overnight, AND MY CAR STARTED IDLING ROUGH, LIKE IT WANTED TO CHOKE OUT, AFTER DRIVING IT AROUND TOWN FOR AN HR, IT STARTED TO BEHAVE LIKE NORMAL, AND WHEN I CLEANED MY WHEEL SENSOR BECAUSE THE TCS AND ABS LIGHTS WERE LIT, WHEN I STARTED THE CAR THEY WERE OFF AND AFTER 12 FEET THEY SHOWN BRIGHTLY THIS HAPPENED ABOUT 4 TIMES, NOW THE LIGHT DOES EVEN FLICKER UNTIL ITS SUPPOSED TO. WELL SEE WHEN I GET BEHIND THE WHEEL TODAY I GUESS
Old Jun 30, 2010 | 12:01 AM
rgh0166's Avatar
5th Gear
-- I'm having the same problem. Is there actually anything wrong?
Old Jun 30, 2010 | 06:27 AM
01tl4tl's Avatar
4th gear- a 99 model year car? or you drive a later year in 4th in town?
ck the motor mounts and trans mounts
cycdaniel
Dec 17, 2019 10:58 AM
udelslayer
1G RDX Problems & Fixes
May 6, 2016 12:27 PM
Sep 17, 2015 09:01 PM
Sep 14, 2015 10:48 AM
siularbar
1/2G MDX (2001-2013)
Sep 11, 2015 10:40 AM
