Electrical Problem (gauges, power windows, shift lock)
Old Oct 24, 2010 | 04:08 AM
eleventure's Avatar
As I was driving to pick up my girlfriend, my broadview rear view mirror cover fell off. As I was trying to put it back on, the whole rear view mirror fell completely off! (while taking a nice chunk of glass with it.) I pulled into a CVS and picked up some rear view mirror glue. I didn't work at all. Out of frustration, I cut the power wire to the mirror to quickly remove it.
Shortly after, I noticed that my entire gauge cluster and power windows were not working. Also, the shift lock was stuck in park. I had to manually shift it into drive. Now, I'm sitting in my garage trying to fix this problem.
-I noticed that all of the things that normally turn on when the ignition switch is in the 2 position doesn't work anymore. (gauges, power windows, etc.)
-when the car is running and I open the door, you hear the beeping sound as you would when you have the keys in the off position.
-checked all the fuses and non of them seem to be blown.
Does anyone know if this is something that is fuse related or is it my ignition switch??
I check all of the fuses and they appear to be fine.
Old Oct 24, 2010 | 04:51 AM
01tl4tl's Avatar
you cut a live hot wire and the system has reacted
fix what you cut to start
Old Oct 24, 2010 | 08:22 AM
eleventure's Avatar
So I finally fixed the problem. Found out that it was a fuse that blew that controlled everything that was not operating. #9 on Drivers side fuse box.
I Had to crimp the wires from the mirror back and glue the mirror back on as well.
While researching, I also found out that the auto dimming mirror is connected to a circuit that also connects to a relay for the transmission. strange......
Everything works now but the check engine light is on. I'll have to check what the code is on Monday.
Old Oct 24, 2010 | 11:10 AM
01tl4tl's Avatar
probably a false code--reset ecu by pulling the clock fuse on passenger end of dash
Old Oct 24, 2010 | 08:12 PM
totaledTL's Avatar
Did you cut more than one wire at a time? If so whatever you used shorted that circuit = a blown fuse that did its job.
Old Sep 22, 2013 | 11:16 AM
gredding's Avatar
thanks eleventure, it was the #9 fuse
Feb 25, 2020 09:57 AM
DwDrummer
5G TLX Problems & Fixes
Sep 14, 2015 08:20 PM
brandnewcolony
Sep 12, 2015 10:39 AM
k6biv
Sep 10, 2015 06:37 PM
ahsm
Sep 9, 2015 08:35 AM
