EGR Flow Insufficient!, What Do i Need to Do?
Old Jun 22, 2006 | 11:56 AM
dvsxlt247's Avatar
99TL-p 114K
Exclamation EGR Flow Insufficient!, What Do i Need to Do?
Well, Had this check engine light for a while. I borrowed a friends computer reader and hooked it up to my 1999 TL-p. I didnt right the exact code number down but it said EGR Flow Insufficient!. What exactly needs to be cleaned out?? Is it the EGR Valve or the EGR Ports. If its the EGR Ports, what needs to be removed and how difficult is this. I also have a Cold Air installed already.
Old Jun 22, 2006 | 01:50 PM
fla-tls's Avatar
On the way!
Do a search. This is a common problem. In fact I think the 1999 has a TSB on it that involved reaming out the port and putting in a sleeve.
Old Jun 22, 2006 | 02:29 PM
fsttyms1's Avatar
use this link and dl the PDF
The actual procedure is in the PDF
https://acurazine.com/forums/showpos...51&postcount=4
Old Jun 22, 2006 | 02:47 PM
aaronnn's Avatar
your cold air doesnt have naything to do with this..
umm i wrote up a DIY a while back for the 99TL. you have to clean out the EGR port, which requires to take out the intake manifold. i'll try to look it up..
Old Jun 22, 2006 | 02:50 PM
aaronnn's Avatar
found it..
https://acurazine.com/forums/audio-video-electronics-navigation-22/wiring-harness-reciever-118568/
some pictures are missing.. but all you have to do is clean all that clog up using throttle body cleaner..
its not that hard to do. any questions just PM me. oyeah and the 99TL intake manifold is totally different from the 00-03. the location of the EGR port is also different. but once you get the intake manifold off, just cleaning it is the problem.
Old Jun 22, 2006 | 03:10 PM
dvsxlt247's Avatar
99TL-p 114K
Thank you Fsttyms and Aarron for all your help and taking the time out to get me those links to the stuff. Thanks alot. Greatly appreciated
[Mod Edit] No calling your resident Genius a Fatty!!!!
Old Jun 23, 2006 | 12:38 AM
aaronnn's Avatar
Originally Posted by dvsxlt247
Thank you Fatty and Aarron for all your help and taking the time out to get me those links to the stuff. Thanks alot. Greatly appreciated
no problem
hahahaha fatty. i know its probably a typo when you wanted to type A but instead hit S.. but that's pretty funny how it sounds like youre calling Kris, fatty.
Old Jun 23, 2006 | 01:06 PM
schen72's Avatar
Please be aware that for 1999 TLs, there is actually a TSB to fix the issue of EGR flow insufficient. Unfortunately, it's covered by warranty only for 8 years or 80000 miles.
Old Jun 23, 2006 | 01:18 PM
fsttyms1's Avatar
Originally Posted by aaronnn
no problem
Fixed
Old Jul 10, 2006 | 08:27 AM
Starmanzzz's Avatar
5th Gear
Egr Tsb
is the warranty extension on the EGR service bulletin also covered for canadian models?
Old Jul 10, 2006 | 02:00 PM
PenancE's Avatar
yup
fifer16
1G RL (1996-2004)
Nov 22, 2024 07:07 PM
CL-S progression 01
Jan 26, 2016 04:15 PM
hashbrown
Sep 29, 2015 12:13 PM
shawnafoxx
1G RL (1996-2004)
Sep 28, 2015 12:33 PM
prbori
Sep 27, 2015 01:37 AM
