ECU help
Old Mar 20, 2009 | 08:28 AM
2ndgentl's Avatar
ECU help
I have a 99 tl I/H/E.................heres my situation. My car runs pretty sluggish at most times, not that responsive, and just not really like it should. When I pull out the CLOCK/BACKUP fuse it resets your ECU. When I do that its like my car comes alive, it is ALOT more responsive from a dead stop and just quicker all around.........but that only lasts about 2 days at tops, then it starts all over again SLUGGISH. WHY!!! I have no CEL, to a person who doesnt know much about cars wouldnt notice it, but I do. When it runs sluggish from a stop I can barely chirp the tires, but when I reset the ECU I can peel them out all the way to 4000 rpms. Its just a lot more responsive. Please help. Thanks.
Old Mar 20, 2009 | 12:53 PM
rob-2's Avatar
Is your vtec kicking in? How's your air filter?
Old Mar 20, 2009 | 04:28 PM
2ndgentl's Avatar
2ndgentl
Yeah, my vtec is always working and my K&N air filter is fine, but the sluggishness is from a dead stop takeoff. The issue is the throttle response when I hit the gas is sluggish and when I reset yhe ECU the throttle response is very sudden, as soon as I touch the throttle there is torque right away which makes my tires spin.
Old Mar 20, 2009 | 04:51 PM
rob-2's Avatar
How dirty is your thorttle body? Is the cable set up properly?
What did you do JUST before you started having this problem?
Old Mar 22, 2009 | 08:11 PM
2ndgentl's Avatar
2ndgentl
Oh, nothing really, I dont remember its been like this for a long time. The only thing thats in the back of my mind is that I do have my cat completely gutted out but I do have that screw on spacer that screws on the cat then you screw on your O2 sensor so it doesnt throw a CEL. Also I have a test pipe in place of the resonator and a test pipe in place of the pre-muffler but I did keep my stock mufflers on for back pressure. And believe it or not my exaust is still not that loud, you cant even hear it over the intake. But you would think if there is an issue anywhere to make the car respond slower a CEL would come on, but I dont have any CELights. But my car will run sluggish off the line, but as soon as I remove that CLOCK/BACKUP fuse and put it back in again my car reacts like it should, very responsive and quicker. A noticably pretty big difference. I dont know, all I know is that now I have to get used to just popping that fuse in and out every other day.
Old Mar 22, 2009 | 10:57 PM
Rajca's Avatar
wham bam thank you ma'am
do u drive like a grandma? at time the ecu will learn your driving patter and u wont have as much power when u want. so by u resetting the ecu it doesnt know what kind of driving was done before.
Old Mar 23, 2009 | 08:59 AM
2ndgentl's Avatar
2ndgentl
NO, I drive with a HEAVY foot, but at times I do try to save gas and drive like grandma.
Old Mar 23, 2009 | 09:50 AM
phee's Avatar
I got the Shifts
turn off TCS
Old Mar 23, 2009 | 12:19 PM
BLK-TLS's Avatar
Where's the ecu located?
Old Mar 23, 2009 | 05:24 PM
Rajca's Avatar
passenger side, right where their left foot would be, towards the fire wall
Old Mar 26, 2009 | 12:03 AM
rob-2's Avatar
problem fixed?
Old Mar 26, 2009 | 08:06 AM
2ndgentl's Avatar
2ndgentl
No, my TCS is ALWAYS off. But still about every two days I have to reset the ECU to make my car come alive.
Old Mar 26, 2009 | 10:53 PM
acurabum's Avatar
After reseting your ECU ,did you do a Idle Learn Procedure ??? It's very important to do it 'cause your car will learn to idle well with load ( light , ac , defrog ..ect ) or no load .....
Most likely your car feels less response after a few days 'cause your idle is more or less stable ...If it idle a bit low = less response or if it idle a bit high = more response ...
Here's the link how to do a Idle Learn according to Acura http://www.in.honda.com/Rjanisis/pubs/SN/B030100.PDF
Old Mar 26, 2009 | 10:57 PM
acurabum's Avatar
Here's the link again !
TypeS860
Jan 10, 2026 11:11 AM
cycdaniel
Dec 17, 2019 10:58 AM
Skirmich
Oct 1, 2015 12:59 PM
malvothegreat
Sep 29, 2015 12:38 AM
siularbar
1/2G MDX (2001-2013)
Sep 11, 2015 10:40 AM
