ECU Backshell - how to remove the female sockets???
Old Jan 31, 2011 | 11:17 AM
racerock's Avatar
I'm doing an engine swap (OK, it is actually on a Honda Accord - 2000) Long time TL poster in other generations... and have a really nice harness with the donor engine, except when the yard removed it, one of the connector backshells was broken... SO my preference is to swap over the backshell from my removed engine and put that in its place...
I've done this with many, many backshells over the years, with work and cars, motorcycles, etc...
This backshell setup is the three connectors to the ECU in the passenger footwell and the backshell has a white piece in it that appears to release the sockets safely from the backshell when you push up on it with a small screwdriver, and not from the side where the pin in the ECU would go into the socket in the backshell.
It appears this way from the cutaway on the damaged one, but when I try it , and I pull on the wire, the crimped to the wire socket (female piece of the connection) does not come out of the backshell...
Any suggestions? I have done a bunch of searches.
My options are:
- figure this out - preferred
Less preferred:
- switch out harness - not preferred because this one is nicer of the two
- splice the connectors with solder and shrink tubing... - there are about 20 connections... not preferred
- trim the damaged backshell and simply push the exposed female sockets on the pins - not preferred...
Thanks.
Old Jan 31, 2011 | 01:03 PM
racerock's Avatar
Well, I did a little more Internet searching and found exactly what I was looking for:
http://www.ff-squad.com/tech/wiring/...in_removal.jpg
However, instead of tearing up the top of the white plastic by pulling it up, you can simply use a small screwdriver and push it up from the bottom...
So, I'll try it tonight...
A person on a Honda forum gave me this as well:
members.shaw.ca/FifthGenTSB1/00-099.Terminal%20Replacement.pdf
though I can't get it to open yet...
Old Feb 2, 2011 | 12:06 PM
racerock's Avatar
The following is the right connector:
Quote:
And I did try the other night in a freezing cold garage. Now, I have been removing pin's/sockets from automotive and military connectors for years...
But...
For the life of me, could not get them out. I'll be trying again, and think I might have it, but ask:
Has anyone removed these? I've done internet searches and find very little on these connectors, except for the above and that website does not look like anyone is there - old updates...
Old Feb 2, 2011 | 10:13 PM
fsttyms1's Avatar
I havent removed that one, but the ones inside the car get removed from the connector side and not the side the wire goes into if i remember correctly with all the repinning i did for my swap.
IBankMouse
Jun 13, 2020 12:53 PM
iRaw
ILX Photograph Gallery
30
Aug 5, 2016 04:41 PM
Skirmich
Oct 1, 2015 12:59 PM
malvothegreat
Sep 29, 2015 12:38 AM
MilanoRedDashR
Sep 27, 2015 10:15 PM
