DRLs not working
Old Apr 25, 2012 | 09:51 AM
digitalextremes's Avatar
02 TL Type-S
DRLs not working
I have a Canadian 2002 TL-S and I have some issue with the DRLs, they don't come on at all, I suspect there is something with the High Beam Cutoff relay as per my testing (based on the service manual), but I need some advise before just going and buying the relay, please let me know if I should be checking anything else that I may have missed?
DRLs don't come on at all when the headlights are at off position and the parking brake is not engaged.
I followed the procedures in the service manual to test the DRL module and all checks gave expected results except for one where the it says there should be continuity but I hear regular beep instead of a long continious tone. See video below.
Also what I noticed is when the headlights are off and the car is ON or with engine running and I flash the hig beams, both (the halogen high beams as well as the HID lowbeams come on), is that normal? I think only the halogen high beams should come on when the headlights are OFF, am I correct?
Old Apr 29, 2012 | 09:10 PM
02 TL Type-S
For those with their DRL module not working properly, you may want to try this before buying a new module
http://www.nyx.net/~smanley/hondadrlfix/index.html
I almost ended up buying a new one but was able to re-solder some of the pins and got it to work like new.
Old Oct 12, 2012 | 11:12 PM
ImperialTL's Avatar
Can you tell me where you found the DRL module?
Old Oct 12, 2012 | 11:15 PM
ImperialTL's Avatar
And how long did the job take you? My local shop quoted me 175 on the part plus 1.5-2 hours labour to change it. I think saving almost 300 is worth the hassle of doing it myself.
Thanks in advance.
Old Oct 13, 2012 | 08:42 AM
victus1's Avatar
The DRL module is located under the driver dash, just above the steering column. You will see a few modules encased in little plastic boxes. The DRL box is blue in my 2000 TL. It's practically impossible to remove the box from that metal clip without breaking it. Just unplug the connector to the module and the circuit board slides out of the box. Make sure to re-solder every single connection that looks suspicious or discolored....especially the ones with the large blobs of solder. Very easy job. Do not pay $300 for this job.
sockr1
Oct 1, 2015 01:31 AM
acurajj
Sep 19, 2015 03:47 PM
JnC
Sep 11, 2015 06:06 AM
spiel08
Sep 7, 2015 08:19 PM
Fadij
Sep 2, 2015 08:31 PM
