DRL Install Problem
Old Dec 22, 2009 | 10:15 PM
TequiLa's Avatar
(ಠДಠ)
Question DRL Install Problem
So I finally got around to installing the DRL module from autobarn.com, but when I went to turn on my car, the low beam and high beam on the driver side was flickering/extremely dim (looks like the voltage was cut between the two, the halogen HB3 was extremely dim and HID D2R was flickering) while my passenger side did not turn on.
These are where each module wire is to be tapped into:
Module > Car
Orange > High Beam
Red > +12 volt
Blue > Ignition Sense Wire
I tapped the orange module wire to the red/yellow high beam wire on the driver side, the red module wire to the battery (+), and the blue module wire to a green/black wire, which I think is the wiper motor relay wire.
I'm pretty bad with electrical wiring and stumped
Old Dec 23, 2009 | 02:17 AM
TequiLa's Avatar
(ಠДಠ)
I tapped the red/yellow wire of the driver side high beam with the orange wire from the DRL module.
I tapped the green/black wire with the blue wire from the DRL module which needs to connect to an ignition sense wire.
^Is the problem in here?
Old Dec 23, 2009 | 08:40 AM
gold2003tl (90)'s Avatar
2003 TL-p
hmm, its hard to tell whats going on without a wiring diagram. i might be able to help more if i had one to look at.
Old Dec 23, 2009 | 02:11 PM
TequiLa's Avatar
(ಠДಠ)
here's the wiring diagram
if you look at the wiper motor wiring diagram, you see the green/black is hot on start.
Old Dec 23, 2009 | 03:45 PM
TequiLa's Avatar
(ಠДಠ)
I tapped the red/yellow wire in the ellipse here:
I tapped one of the green/black wires in the ellipse here to get access to the ignition sense wire:
Old Dec 23, 2009 | 03:48 PM
2003 TL-p
ok, i am taking a look at the diagram, but bare with me it might be a little while before i get back to you with a good answer.
i am not sure if you connected the(+) passenger side high beam to the drivers side hid(-), and possibly tied in the drivers side high beam(+) too?
basically (+) is going into the DRL unit and coming out at like 50% power into the (+) of both the high beams. correct?
it seems like you did things right, but i am unsure how you tied in the drivers side HID.
Old Dec 23, 2009 | 03:58 PM
TequiLa's Avatar
(ಠДಠ)
could it be that i was supposed to connect the orange module wire to the (-) side of the driver side high beam? cuz the module is getting power from the (+) side of the battery
Old Dec 23, 2009 | 04:58 PM
jjashaa's Avatar
Avant Garde Wheels
you should try where the light switch stalk is.
orange/white wire.
Old Dec 23, 2009 | 05:32 PM
TequiLa's Avatar
(ಠДಠ)
i tried the oj/white wire coming out of the driver high beam just now and when i started the car both highs started out dim then faded out while the driver low flickered and turned off
Old Dec 23, 2009 | 11:16 PM
TequiLa's Avatar
(ಠДಠ)
Old Dec 23, 2009 | 11:56 PM
TequiLa's Avatar
(ಠДಠ)
this is the installation manual
http://www.hoppyonline.com/autoacc/inst/20013v2-1.pdf
cycdaniel
Dec 17, 2019 10:58 AM
HOWELLiNC
Sep 10, 2015 01:39 PM
spiel08
Sep 7, 2015 08:19 PM
NSolace
Sep 3, 2015 08:02 PM
Fadij
Sep 2, 2015 08:31 PM
