Drivers side fan not coming on
Old Aug 1, 2011 | 04:42 PM
grahampham's Avatar
Question Drivers side fan not coming on
Car started running hot (mostly when the outside temp is around 100) especially with AC on. When I turn AC off I noticed the temp drops to normal pretty quick. It seems the drivers side fan is not coming on. i disconnected the wire on top leading to the fan and see there is power there... Does this mean i need a new fan motor?
Old Aug 1, 2011 | 05:00 PM
acutee's Avatar
It could be the temperature sensor. check the motor if it is good, then it is the sensor.
Old Aug 1, 2011 | 05:05 PM
grahampham's Avatar
How do I check the motor? There is power going to it...
Old Aug 1, 2011 | 07:05 PM
01tl4tl's Avatar
swap power with other fan and operate ac,,should cause driver fan to come on with ac then
does the fan spin freely by hand?
most common failure is fan temp sensor
Old Aug 1, 2011 | 08:28 PM
grahampham's Avatar
Thanks... I will give it a try
Old Aug 2, 2011 | 02:32 PM
grahampham's Avatar
The wire for the passenger fan will not reach the drivers side (or vice versa) to check it can I just stick wires in to each connector?
I believe the sensor on my car (2000 TL) is located on the thermostat housing... Do I need to drain the coolant to replace this?
Old Aug 2, 2011 | 05:29 PM
01tl4tl's Avatar
99s were at thermostat, and will have 2 sensors, one fan one temp
00 and on should have 1 sensor there for dash guage
but look at lower pass corner for a screw in unit with 1 wire as fan temp sensor
YES you can use any diy jumper wires to get power to fan for testing
thats why diy is all about! creativity in need
Old Aug 2, 2011 | 05:32 PM
01tl4tl's Avatar
either place, fluid loss is minimal
so turn heater to hot- start car and let warm up with rad cap off
fill rad as needed
just BURP the system for possible air, no need to drain fully
UNLESS
you have 5+ years on the coolant in which case DIY change that and get the engine block drain bolt too!
Old Aug 2, 2011 | 06:41 PM
grahampham's Avatar
I think the 2000 is the same as the 1999. Is this the part I am looking for (#15)? Is the fan switch and temp sensor the same thing?
http://acuraautomotiveparts.org/acur..._%28HADSYS%29#
Old Aug 2, 2011 | 09:05 PM
01tl4tl's Avatar
does your car look like that?
Old Aug 3, 2011 | 01:22 PM
grahampham's Avatar
From what I can see. I haven't taken the engine cover off yet. Have to get time away from work to get into it.
I can see 2 sensors on the thermo housing... one is bigger than the other and comes out sorta sideways (not straight up). Is it the water temp sensor that triggers the fan to come on?
Old Aug 3, 2011 | 06:44 PM
01tl4tl's Avatar
take the engine cover off then we can assist you
Old Aug 3, 2011 | 07:20 PM
grahampham's Avatar
Will do... planning on tomorrow. I can see the Thermo housing though
Old Aug 3, 2011 | 09:41 PM
01tl4tl's Avatar
Im an 01, so cant help directly with visual, going off general knowledge of gen2
read recent thread on sensor replace on a 99 - how he figured out which one was temp guage,,,and replaced it (different prob)
Old Aug 4, 2011 | 10:12 AM
TLer trash's Avatar
If you've got power to the fan motor, you've eliminated the fuses, sensors, ecm, and relays. If the ground is also good, you need a new fan motor.
Old Aug 4, 2011 | 10:40 AM
01tl4tl's Avatar
trash- cant you get power at the connector to fan, but not get sensor signal to complete the path to open or ground,,
or is it hot power means entire circuit good?
me not understand electrical very well~
trying to learn as worthless info discarded and more brain cells avaliable~
Old Aug 4, 2011 | 11:11 AM
TLer trash's Avatar
I don't think so. Sensor(s) tell the computer to trigger relay(s) which in turn supply power to the fan(s). Unless the relay were stuck on, everything in the circuit has to be working.
Old Aug 4, 2011 | 08:17 PM
grahampham's Avatar
Replaced the sensor and both fans working now. That was an easy fix. However... my check engine light came on now... is that because I didn't disconnect the neg battery terminal? Since the sensor is connected to ecu?
Old Aug 5, 2011 | 02:06 AM
01tl4tl's Avatar
not usually, but you never know
do an ecu reset with the clock fuse on passenger end of dash
if it comes back -(seeing you live in Ca where stores cant code scan for you)-
use Regions section to find a ziner with a scanner
or a muffler shop for diagnosis. smog rules allow that loophole~
Old Aug 5, 2011 | 02:07 AM
01tl4tl's Avatar
where is the fan sensor located on your 2000?
Old Aug 5, 2011 | 08:08 AM
grahampham's Avatar
Located on the water pump housing. I had some code issues due to the tranny but Aamco just put in a new torque converter. Car seems to run great except a slight misfire which I think is a bad coil pack diagnosed when my tranny failed last year.
Old Aug 5, 2011 | 10:55 AM
01tl4tl's Avatar
better get a coil and find out which is bad
you will need to reset the ecu after that fix
most likely its the code now
Old Aug 5, 2011 | 05:48 PM
grahampham's Avatar
Had the code checked at Midas, it was giving radiator water hot and radiator water cold codes... So I think the ecu freaked out when I changed the sensor without first disconnecting the neg battery terminal.
Thanks for all the help!
Old Aug 5, 2011 | 06:03 PM
01tl4tl's Avatar
with the amount of bad info that sensor has been giving the ecu-
not a bad plan to force a full reset and relearn with the `clock fuse method`
remove for 1 minute and reinsert
did you mean on 99-00 its located on the `thermostat housing` on top of engine
not the water pump housing- located on front of engine?
again Im an 01 and looking for correct info to share
how much was the sensor and what did the parts place call it on the receipt?
Old Aug 6, 2011 | 02:27 AM
grahampham's Avatar
It is # 15 on the link... Thermo housing.
What is the clock fuse method?
Old Aug 6, 2011 | 09:27 AM
01tl4tl's Avatar
clock fuse located in small fuse panel on passenger end of dashboard
remove it for about 1 minute and reinsert
Its the secret backup power to the ecu
battery neg cable method requires you input the radio code,,
clock method doesnt effect that but will do what we want..quick clean and easy!
Old Aug 9, 2011 | 09:21 AM
grahampham's Avatar
Awesome... I didn't know that. Took care of it last night. Car has been running good (aside from the slight misfire). This has been a great site! With the help from all of you I have literally saved hundreds if not thousands of $$$. I replaced my front pads and rotors not too long ago and I was worried after reading some of the posts about how hard it was to remove the rotors... however, mine came right off... easy easy fix. the entire job was under an hour. And the temp sensor was by far even easier than the brakes. This economy is forcing me to do the repair work myself, but I am actually thankful for it... it is rewarding!
Old Aug 9, 2011 | 10:01 AM
01tl4tl's Avatar
the only difficult part of the brake job is the 2 screws and there are tricks for the removal
Everything on the car,,,is just bolts!
only limit for DIY is how many layers of skin off your hand are you willing to give up--
in exchange for the job being done to your own high standards?
and not pay 100 an hour for a 10 buck an hour employee to turn those same bolts~
buy yourself lunch for the 2 diys,,well done~
Old Jul 15, 2012 | 04:48 PM
madison87's Avatar
Hey guys, same problem here, driver side fan wont come on. What was done: relaced motor, checked temperature sensor, replaced fan switch A, checked fan relay. What is going to be next ?
Old Jul 16, 2012 | 01:10 AM
JDTL-S2002's Avatar
since thread was bumped, still having the same problem. My passenger side fan roars on when the car is cut off, but stops immediately when key is turned to "on" position 2002 type S.
Changed fan sensor/switch on radiator...
Old Jul 16, 2012 | 01:20 AM
madison87's Avatar
do you know if I have one too on 99 ? Where is it located(switch on radiator)? I replaced the one which is on engine, driver side under air intake.
Old Jul 16, 2012 | 09:21 AM
JDTL-S2002's Avatar
No the 99-00 only has a coolant fan switch in the cylinder head, whereas the 01-03 has one in the cylinder head as well as on the radiator.
nanos
Nov 12, 2015 08:41 PM
sockr1
Oct 1, 2015 01:31 AM
JnC
Sep 11, 2015 06:06 AM
gqdabien
Sep 8, 2015 11:41 PM
08 NBP TL
Sep 8, 2015 08:49 PM
