Driver's door- not locking
Old Oct 10, 2012 | 09:42 PM
nollid's Avatar
99 Acura TL
When I press lock/unlock on my keyless remote, the driver's door is not locking, the lights blink, 3 doors lock, no beep (b/c front door isn't locking).
When I press lock/unlock from the driver's door or passenger's door, same results. When I hold the lock knob and press the lock button, I don't feel any motion as if it is slipping or something.
Only by manually pushing down the driver's door lock knob, or using the key on the outside and turning, can I look the door.
My question, to save me some time, is could this be related to a fuse or the mechanics and need to take off the driver's door to investigate.
Old Oct 11, 2012 | 07:05 AM
3.2TLc's Avatar
Hey Nollid, by the way that you explained everything working except the driver's door....It's probably something that will require the door's inner panel to be removed.
More than likely a bad switch or actuator in my opinion.
Old Oct 12, 2012 | 11:23 AM
RicanTL99's Avatar
it might be something our cars are known for because im having the same problem. i believe its the door lock actuator
Old Nov 22, 2012 | 09:30 AM
mrbustrbrown's Avatar
my passenger door does it tooo,but when its cold outside it works,when its hot it doesnt...wont lock or unlock when its hot,but functions when its cold? wtf
Old Dec 24, 2012 | 03:02 PM
FlyingEK's Avatar
in the same boat here , iam gonna try to replace the actuators next weekend and c what i come wup with
Old Dec 24, 2012 | 03:50 PM
fsttyms1's Avatar
Dont replace anything yet. Take the lock/latch mechanism out of the door and make sure that every thing moves freely. i have seen many rust up. If that is your case just get some penetrating oil and soak it in it and manually free it up.
blacktsxwagon
Oct 27, 2015 10:12 PM
lanechanger
Oct 13, 2015 10:56 AM
DementiaPhuro
Sep 29, 2015 05:31 PM
xsilverhawkx
Sep 28, 2015 06:51 PM
chiu0nthls
3G MDX (2014-2020)
Sep 28, 2015 03:46 AM
