driver head light not working
Old Oct 10, 2009 | 05:39 PM
whattheydokid's Avatar
4th Gear
Driver head light is not working. I thought it was the bulb but its not. When i turn the light's on the right side work fine but the left side does not also i think the low beams comes on also and my fog lights does now work at all.. help some one its soo lame to drive around with one light on
Old Oct 11, 2009 | 01:03 AM
juanclopez2786's Avatar
check all the fuses to make sure none have blown. then check with a test light to see if you have power to the ballast whenu turn on the headlight switch. if you do then you ballast is bad.
Old Oct 12, 2009 | 07:08 PM
Rajca's Avatar
wham bam thank you ma'am
did u switch the bulbs left to right and right to left? switch the ignitors next and then the ballast. time consuming but can save u tons of money in the end
Old Oct 12, 2009 | 09:33 PM
alebastardo's Avatar
Rajca,
I am having a similar problem and switched the bulbs and therefore the next step is to do the same with the ballast and ignitors.
Question: To switched the ignitors, do you have to do it taking the bumper off as it is required to access the ballasts?
Old Oct 12, 2009 | 09:43 PM
Rajca's Avatar
yes. the ignitor connects the ballast and the hid bulb.
mada51589
Jan 9, 2025 04:40 PM
Feb 25, 2020 09:57 AM
Ny1718
Sep 11, 2015 09:21 AM
theinsvnity
Sep 10, 2015 10:22 PM
