Door wont open
Old Mar 24, 2007 | 12:30 PM
Chris_N's Avatar
Door wont open
I have a 99' tl that has the rear passenger door closed/locked and with a seized locking mechanism. Does anyonw know how to remove the door panel with the door closed or how to access the mechanism to be able to lubricate it ?? This happened to my driver side rear door, but I caught it early and was able to get the door open, and use wd-40 / grease to release the mechanism and then lubricate it(been working great for 8 months so far).
Old Mar 31, 2007 | 01:16 AM
VeEzy's Avatar
B A N N E D
my driver's lock wont open or close w the keypad or switch inside the car the only way i can open it is with my key or if i pull it... any advice for me? sorry i cant help you
Old Mar 31, 2007 | 05:07 AM
vzuptnguyen's Avatar
B A N N E D
its not the child safety lock is it?
Old Mar 31, 2007 | 11:13 PM
3.2VtecTL's Avatar
I've got the same problem except my driverside rear door, will not open from the inside or outside.... and i'm not able to check to see if the child lock is on, but wouldn't it open from the inside if it was enabled?
bump for a fix....
Old Apr 1, 2007 | 01:33 AM
VeEzy's Avatar
B A N N E D
nahh it sounds like it trys to open but its stuck or something
Old Apr 1, 2007 | 07:57 AM
heisnuts's Avatar
If you plan on working on the car yourself, I would suggest buying the service manual for the car. It gives great step by step directions on how to remove and replace just about everything on the car. It can be found at www.helminc.com
mlody
Dec 4, 2019 02:11 PM
Jul 16, 2017 07:33 AM
soupi
14
Nov 15, 2015 11:15 AM
Sue1910
2G CL Problems & Fixes
Sep 27, 2015 12:34 PM
ceb
ILX
Sep 27, 2015 10:56 AM
