Door Locks and Alarm
Old Nov 14, 2006 | 12:02 AM
VeEzy's Avatar
B A N N E D
for some such reason i cant unlock my door by pressing the unlock button on my keypad. it makes the noise it normally makes when you unlock it but nothing happens; all the door locks stay down. only way 2 open it is with the key. when im inside the car and i push the unlock switch on the door up all doors except the driver's unlock. i kept pressing unlock/lock on both the door switch and the keypad but the drivers side wont unlock. the only way i can get anything to unlock is if im inside the car and use the switch keypad does nothing, but switch unlocks everything but the drivers door. what should i do?
i cant activate the alarm by using the keypad either (pressing the lock button twice wont activate the alarm). the only way i can get the alarm to activate if i lock the drivers door manually. then when i press the button twice it activates.
i search and found something called valet mode but that didnt seem to fix the problem... stock alarm btw batteries in keypad r fine.. i even tried using both keypads.
Old Nov 16, 2006 | 11:40 PM
clue036's Avatar
im having the same problem also. my driver and back right passenger locks do not work. both have to locked/unlocked manually. i dont really know what it could be. i think ima go visit the dealership in the morning because my car has been acting up the past week. i'll let you know if i find out anything
Old Nov 17, 2006 | 05:17 PM
VeEzy's Avatar
B A N N E D
^thx. im gonna go to the dealer too hopefully this weekend unless some1 knows of a quick fix for this
Old Dec 27, 2006 | 03:24 PM
VeEzy's Avatar
B A N N E D
bump! help plz
Old Dec 27, 2006 | 05:05 PM
tim'sTLS's Avatar
If your under warranty, take it in. If not, pull off the door panel and check it out. If your car was ever slim jimmed some of you would know what I'm talking about. Check all the mechanisms and rods for looseness.
Old Dec 28, 2006 | 12:50 AM
VeEzy's Avatar
B A N N E D
k thx. i dont think my car was jimmied or at least i hope not
Old Dec 28, 2006 | 12:53 AM
03CoupeV6's Avatar
05 C230K & 09 135i 6MT
I've had these problems in my 99 Accord, and I'm assuming that the locking mechanisms are the exact same parts as in the 2nd gen TL. It was bad actuators. $60 repair.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
soupi
14
Nov 15, 2015 11:15 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
Sue1910
2G CL Problems & Fixes
Sep 27, 2015 12:34 PM
