Door Locks and Alarm
for some such reason i cant unlock my door by pressing the unlock button on my keypad. it makes the noise it normally makes when you unlock it but nothing happens; all the door locks stay down. only way 2 open it is with the key. when im inside the car and i push the unlock switch on the door up all doors except the driver's unlock. i kept pressing unlock/lock on both the door switch and the keypad but the drivers side wont unlock. the only way i can get anything to unlock is if im inside the car and use the switch keypad does nothing, but switch unlocks everything but the drivers door. what should i do?
i cant activate the alarm by using the keypad either (pressing the lock button twice wont activate the alarm). the only way i can get the alarm to activate if i lock the drivers door manually. then when i press the button twice it activates.
i search and found something called valet mode but that didnt seem to fix the problem... stock alarm btw batteries in keypad r fine.. i even tried using both keypads.
im having the same problem also. my driver and back right passenger locks do not work. both have to locked/unlocked manually. i dont really know what it could be. i think ima go visit the dealership in the morning because my car has been acting up the past week. i'll let you know if i find out anything
If your under warranty, take it in. If not, pull off the door panel and check it out. If your car was ever slim jimmed some of you would know what I'm talking about. Check all the mechanisms and rods for looseness.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
soupi
14
Nov 15, 2015 11:15 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
