Door Console/Handle
Old Nov 8, 2006 | 02:53 PM
Dan01TL's Avatar
Door Console/Handle
The panel for the passenger side rear door is separating from the console/handle portion {i.e. the part that has the window switch} of the door. It appears that the glue that holds the foam backing of the panel has let loose. Has anyone had any experience with this type of problem? I would appreciate any help regarding how to repair it. I have a 2001 TL. Thanks in advance.
Dan01TL
Old Nov 8, 2006 | 03:40 PM
dunlax072's Avatar
Mine is doing that too, I was going to just glue it back in place but I keep forgetting about it because it's in the back seat.
Old Nov 8, 2006 | 04:55 PM
fsttyms1's Avatar
Many have had the problem You have 2 options. (if not under warranty) replace the whole door panel, or 2, take it off and try gluing it Back. Some have had luck gluing it.
Old Nov 8, 2006 | 04:59 PM
Bambo2888's Avatar
they go wooooot wooooot
i think over 70% of TL owners will experience this problem. Both TLs in my family (2000 and 2002) both have had this happen.
What kind of glue would work?
Old Nov 10, 2006 | 08:38 AM
Hitlayers's Avatar
Same problem here, glue recommendations??
Old Nov 10, 2006 | 10:05 AM
fsttyms1's Avatar
I dont have this issue, but maybe try gorilla glue?
Old Nov 10, 2006 | 12:11 PM
Bambo2888's Avatar
i dont think gorilla glue would be a smart choice because it expands as it dries... i think it would make a huge mess
Old Nov 10, 2006 | 01:15 PM
GranSkyline's Avatar
Vroom
i'm having the same problem, drivers side rear seat, i have a '99
Old Nov 10, 2006 | 01:36 PM
fsttyms1's Avatar
Yea if you use alot. Alot isnt needed. There are a few threads on it and what people used. Run a search and see.
Old Nov 11, 2006 | 06:26 PM
Rpappi's Avatar
DRINKING HAS A ME PROBLEM
yup both rears for me.
Old Nov 15, 2006 | 10:47 AM
twighunter00's Avatar
I had this problem in My TL with both rear doors... I fixed it...dont' have pictures but I can explain pretty easily...
All you need is painters tape...and Super Glue, (you can go to a discount auto and they'll give you specialized super glue which is what I used I think...but any super glue is fine...as long as it can hold ur fingers together with the slightest amount)...
I had a bottel u can squeeze with a point on the end which was easier for applying (the entire tube was maybe 4 inches long)
Get somebody to help u and put a line of glue on the panel (not part conected to the window switch) There should be a lip on the end of the piece falling off. Put glue all on that lip all the way than you and your friend push it into the door panel. You kind of have to push down to get the lip under the window switch part. Once you get the lip in to where it looks good, take the painters tape (or something strong, ducktape isn't good because it'll leave a residue) and tape maybe 15 pieces vertically holding the door panel's nice and tight together. I left my tape on for aprox. 2 days.
It looks great now, just be careful with that glue, cause its very hard to get off...Don't want to be careless and miss something and get it on the actual panel. If theres any residue on the door after you take the tape off than just use goo gone on a clean rag and it'll come right off... just don't use to much goo gone or it could get to where the glue is....
Hope this helps, Its actually really simple, took me maybe 10 minutes for both doors.
Old Nov 15, 2006 | 04:45 PM
Bambo2888's Avatar
thats kickass, im gonna try it
soupi
14
Nov 15, 2015 11:15 AM
BIGxRED
Oct 19, 2015 10:47 PM
chiu0nthls
3G MDX (2014-2020)
Sep 28, 2015 03:46 AM
Sue1910
2G CL Problems & Fixes
Sep 27, 2015 12:34 PM
ceb
ILX
Sep 27, 2015 10:56 AM
