dirty egr or idle control valve?
Agean Blue Bishes
1 Post
some times when i just rev my car slightly in neautral or when i come to a stop. the rpms will drop and dip lower then what idle is and the car struggles for a second then hops back up to idle.
only does it when the rpms drop. if i just let the car sit and idle nothing like this happens.
not quite sure what it is. doesn't do it every single time but probably 50 percent of the time.
just a side effect of me neading a tune up at 107,000
my friend who is a mechanic says it could be a possible vacuum leak......?have to look into it....
Its could be your EGR. My car does the same thing and is giving me a 1491 code for EGR flow but my car does this when both CEL and TCS light come on-if the TCS light is off my car idels fine? I'm new so bare with me.
most likely its in the programing of the computer
Timslunch2 your egr ports need to be cleaned. Do a search for egr cleaning and you will find links and diy's that show you how to clean it
Demolition-x . Did you find out what 's wrong with your car ??
I got the same problem but only happen30% of the time when
the car is idling at the red light intersection ! maybe it is the IVAC
but wonder if my old ( 02 tlp ) radiator anti-freeze might make
the IVAC misfunction ? Time to flush and change the anti-freeze
and hope the problem will disappear >
Agean Blue Bishes
1 Post
and hope the problem will disappear >![Wish](https://acurazine.com/forums/images/smilies/wish.gif)
its not really a problem, just something i have noticed.
when my tank gets to a 1/4 tanks im gonna run some injector cleaner see if it helps.
if it actually does stall thats when i will take it to the dealer. dunno how they would act if i have an intake
Originally Posted by Timslunch2
I'm on top of it. The DIY looks to easy to be true are there any curve balls to those direction or is it straight foward? Thanks for not flaming me.
same thing happens to my car could be egr low flow
Before changing the ICV I would recommende changing your Radiator Coolant first.!
99 SSM Tl
