D5 Light Off ?
D5 Light Off ?
Hi all,
First i'd like to say im really glad i found this forum and i've found many answers to most of my questions so thanks alot.
I've recently bought a 3.2TL 2003 Premium for 3000$ with 240 000kms on it and the tranny was replaced at 220 000kms at the Acura Dealer (which is a good thing since i read these transmission are kinda weak) but ive noticed a weird problem with the D5 Light..
I know flashing D5 = problems but mine just doesnt light up at all.. I thought it might be the light bulb but the thing is If i put the car on D5 and then switch to neutral, the neutral light wont light up unless i slam the shifter really hard.. Neutral will still engage even if the light is off tho. Also, if i put the car on D4 and then switch to D5 and try to use SportShift, it wont work, i have to drop it in neutral and then put it in D5 and then switch to SportShift in order for it to work.
From my understanding, it sounds like a cable problem or something with the shifter since i have to slam it from D5 to Neutral to make the N light up.
I've looked all over the forum but i didnt see anyone with this problem and i would really like to try and fix this. Any help would be greatly appreciated.
Thanks Alot.
Thanks Alot.
The following 2 users liked this post by Skirmich:
01tl4tl (06-15-2012),
Midnight Mystery (10-19-2019)
Is there any evidence of soda drink spillage in the cup holder, or any fluid leaks in the cd storage area (people put strange things in there)
those both drain directly onto some microswitches under the shifter
I would try a trans shop first, tell them what its doing- put it on the lift
may be a 20 dollar adjustment
If the trans was done recent enough the acura dealer should inspect their work free
drop by and ask the SERVICE MANAGER (not service writer) to come sit in the car and demonstrate the problem
The transmission was done more than a year ago (1year and 3 month precisely) so its out of warranty, the dealer wouldnt even look at it, he did tell me that the Transmission rear main seal is leaking a little tho.. i was a little bit frustrated since it has been rebuilt TWICE one year ago... anyway ill just keep topping it for now
i found out that soda or something definitely has been dropped in the shifter and the cup holder, there was traces of spilled stuff everywhere when i removed the shift knob and the metallic plastic piece, and i also noticed that the shifter lights doesnt light up at all.. so D5 and Neutral doesnt light up on my dash(unless i get from Reverse to Neutral in which case Neutral does light up but not D5) and all the shifter lights are out..
I would like some advices on how to take the shifter assembly out and clean it and maybe fix the problem, where are those switches that can be affected? Thanks alot.
D5 light
There is nothing wrong with the transmission, I think your D5 light is messed up. I have the same issue,doesn't bother me. D4,3.2... working fine but not d5
Hi all,
Thanks Alot.
Thanks Alot.
Tranny replaced now dash gear light off and shifter jiggling
I just had a refurbished tranny put in two days ago and everything is fine except the dash gear light don't light up and my shifter sounds like it's jiggling around anybody have a idea whatight have happened and today my first gear didn't want to engage until the car had warmed up
mada51589
05-03-2022 08:54 PM
sockr1
10-01-2015 01:31 AM
wusty23jd
09-24-2015 11:41 AM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
