D5 flashing need help
Old Mar 28, 2009 | 10:44 AM
ENISHO-TEE's Avatar
As I was driving,the D5 on shift selector started to flash. so I pull in to the nearest parking lot,put it in park and D5 still flashes. Then I turn off the car and waited for a few minutes. I then started up the car,D5 wasn't flashing,and proceeded on driving. Ten minutes later D5 started to flash again. I stopped to checked the owner's manual,it indicated a possible transmission problem. The TL seem to be running fine. No signs of mechanical malfunction as of now. I have an 02 TL-S with 86,000 miles. Had the oil jet installed due to the recall two yrs ago. I had the Honda dealer flush n fill the transmission fluid in june 08. Could it really be a transmission problem or electrical malfunction? If it is a transmission problem. Will I need a whole new tranny and how much? what are my options? Any info or help is greatly appreciated. THANK YOU!!!
Old Mar 28, 2009 | 11:17 AM
bass222000's Avatar
not sure , but I believe the flashing D5 is the first sign that the trans is getting ready to go.
Old Mar 28, 2009 | 11:28 AM
Wish I Had A TL's Avatar
Cool
X2. I would take it to the dealer RIGHT away.
Old Mar 28, 2009 | 01:04 PM
niju321's Avatar
you probably need a new tranny, sorry. take it to the dealer and see what your options are--you might have some time left under the extended warranty, in which case the tranny will be replaced for free.
Old Mar 28, 2009 | 01:15 PM
acurabum's Avatar
D5 flashing = detect a problem in the Transmy ....but it could be anything ......
Mine flash and it turn out that I need a ATF temp sensor ( 200 $ )
Old Mar 28, 2009 | 01:35 PM
TequiLa's Avatar
(ಠДಠ)
does it slip when you try to shift gears?
Old Mar 28, 2009 | 01:38 PM
acurabum's Avatar
Go to Autozone and get the car scanned for DTC code then you should be able to tell what is wrong !!!
Old Mar 28, 2009 | 03:27 PM
fsttyms1's Avatar
Get the code read. Flashing D5 means MANY things. Most common are a trans thats about to fail or most other common is a ATF sensor malfunction
Old Mar 28, 2009 | 05:25 PM
ENISHO-TEE's Avatar
It drive fine as of now,no slippage
acuratl26
Apr 23, 2020 07:30 PM
SilverJ
4G TL Problems & Fixes
15
Oct 13, 2015 05:14 PM
DementiaPhuro
Sep 29, 2015 05:31 PM
thegipper
Sep 28, 2015 01:01 PM
ceb
ILX
Sep 27, 2015 10:56 AM
