D5 clanking over 40
Old Aug 17, 2012 | 10:09 PM
AcuTypeS02's Avatar
6th Gear
D5 clanking over 40
Hey, I recently bought an 02 type-s with 146k.
After buying the car, i noticed that when going into 3rd gear the car shimmies back and forth when accelerating slowly. Also when going over 40 mph (only a few times this happened) there is a sort of rattling or clanking sound coming from the tranny or somewhere. The weird thing is that this only happens in D5 with gives me the idea that maybe d5 is starting to deteriorate or the the gears are loose or something.
Does anyone know if overdrive/D5 is external to the transmission like in a few cars? Also just wondering if anyone else has ever experienced this in their tl?
Old Aug 18, 2012 | 03:48 AM
Karanx7's Avatar
Unregistered Member
5th gear should engage at 45 mph. It does sound tranny related though...
Hope it's not too bad.
Old Aug 18, 2012 | 08:15 AM
01tl4tl's Avatar
ck normal things= motor mounts steering suspension
how does the atf look and smell?
Old Aug 18, 2012 | 10:53 PM
AcuTypeS02's Avatar
6th Gear
The fluid is a little red-brownish but i got it changed a few weeks ago. I need to get it changed again because its been awhile and all the crap probably got into the fluid. I keep it in D4 while driving locally and it goes up to about 70/75 in fourth.
Old Aug 19, 2012 | 08:10 AM
3.2TLc's Avatar
Having just recently purchased the TL with the higher miles, it would help if you knew the previous maintenance was regularly done. If unknown, then start from fresh. Find out if the recall work was performed and if the tranny was replaced at some point.
Another drain 'n fill of the tranny can't hurt at this point. While you're at it....replace the "hidden" transmission filter. The DIY is nearby. Also, an alignment shop could inspect your front end suspension up on a rack and tell you what may need attention.
Old Aug 19, 2012 | 09:44 AM
01tl4tl's Avatar
STOP!!!!!!!!!!!!!!!
what fluid exactly did you use and what method of replacement??
basic gravity drain and refill 3.4 quarts?
if a shop used dextron3 your trans is toast and its their fault
dex3 forbidden in the TL... and why acura came up with the 3x3
for times of small addition of dex3 by accident!!!!
the correct stuff for us is honda DW-1
our filter is external on the top..25 bucks aftermarket
not inside the pan like older cars
Old Sep 10, 2012 | 07:32 PM
AcuTypeS02's Avatar
6th Gear
the shop used dw-1 and a couple of days ago i did it again
Old Sep 11, 2012 | 10:53 AM
01tl4tl's Avatar
iirc 2nd shares with 5th gear so loss of clutch material would affect both
continue to use gear D4,,it just became a 4 speed auto!
clean the shift selenoids (external) and replace the filter- also external
look at bolts mounting brackets to trans and bolts holding trans to engine
see blue paint on them? thats a warranty unit
Fuda
1G TSX Problems & Fixes
May 31, 2008 08:45 PM
zootjeff
Sep 24, 2007 09:46 PM
euroStyle
Jun 13, 2007 11:24 PM
handydandy
May 10, 2007 06:02 PM
russianDude
Aug 29, 2002 12:40 AM
