CV Boot damaged and leaking.
Old Jul 19, 2006 | 03:39 PM
Leo Type-S's Avatar
03' NBP TL-S
The dealership said my right outer CV boot is split open and leaking fluid. They quoted me $185.00 to fix it. That seems a little steep. Where can I take my car to get this fixed? I don't know what a CV boot is. Can someone shed some light on this and help please?
Old Jul 19, 2006 | 03:51 PM
Leo Type-S's Avatar
03' NBP TL-S
http://oem.overnightautoparts.com/pa...ory=K&dp=false
can someone check that out and see if that's the correct parts. does anyone know where i can order it maybe, and have someone install it. would that total come out to be less?
fsttyms1's Avatar
the CV boot is the rubber boot on your half shaft. (driveshaft)
They have to take it off the car to fix it, thats why it costs alot. You dont want to let it go, the half shafts are expensive to replace and can cause more damage as they wear. If for some reason you think thats alot check around with tranny rebuilders and other independant shops to see how much they charge to do the work
Old Jul 19, 2006 | 03:53 PM
Bob_F's Avatar
The CV boot surrounds the Constant Velocity or CV joint and keeps it lubricated. You definitely want to take care of it right away in order to keep the CV joint from failing.
Here's some more info:
http://www.samarins.com/glossary/cv_joint.html
$185 doesn't sound outrageous for a dealership but you might want to get quotes from a couple of other places.
Bob
Old Jul 19, 2006 | 03:55 PM
fsttyms1's Avatar
check out this place. they are cheap with oem parts and are fast to deliver.
you may also need to know if its a outer boot or inner boot.
look under driveshaft
http://www.acuraautomotiveparts.org/...catdisplay.jsp
Bob_F's Avatar
And what fsttyms1 wrote... :-)
Bob
Old Jul 19, 2006 | 03:56 PM
fsttyms1's Avatar
its not the parts that are bringing the cost up, its all labor from having to remove the driveshaft
Old Jul 19, 2006 | 04:56 PM
Leo Type-S's Avatar
03' NBP TL-S
thanks guys. i guess i'm just going to have the dealership work on it. i didn't know that part with so difficult to change out.
Old Jul 19, 2006 | 04:58 PM
fsttyms1's Avatar
Its not, most shops can do it, its just a part that is a little more involved to take off than a wheel
Old Jul 19, 2006 | 07:45 PM
honda_inspire99's Avatar
Skeet Skeet Skeet
just buy one and change it yourself i just changed mine its just like any other honda/acura
Old Jul 19, 2006 | 09:35 PM
PenancE's Avatar
if its a small hole, cant u just patch it up?
Old Jul 20, 2006 | 03:01 AM
Leo Type-S's Avatar
03' NBP TL-S
no.. it's actually split pretty big
Old Jul 20, 2006 | 02:48 PM
Edward'TLS's Avatar
6G TLX-S
If the split is that big, most of the grease inside will likely have spitted out due to the rotating shafts. The dry CV joints will wear out in no time, and are much more expensive to fix. So get it fixed ASAP.
Old Jul 20, 2006 | 03:05 PM
fsttyms1's Avatar
and what are you going to patch a CV boot with?
Old Jul 20, 2006 | 05:27 PM
Skeet Skeet Skeet
bro just go to advance auto and get a new axle its $79.99 with your old one
Old Aug 12, 2006 | 01:19 PM
DiveforTL-s's Avatar
Why I watch sci-fi...
get it fixed... i had a Probe GT (it was cool at the time) and the boot went. I did not know what it was. I was 19. well, once it was all said and done I shelled out $1200 (witha tow 45 miles). Or i could have spent less than $200 and had someone fix it.
Old Aug 12, 2006 | 01:42 PM
optomos's Avatar
I=X - optomos
If all the grease is gone and dirt got in, its already to late. You might want to think about getting a reman from your local auto parts store and install it yourself or your mechanic.
For the same cost in labor you can have the new axle installed and not have to worry about the possibility of having to replace it anyway and pay again for the labor, which is your primary expense.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
Mike734
Dec 10, 2021 01:25 PM
Jinkazetsukai
Nov 21, 2015 05:28 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
