Cruise Control Actuator Motor. How hard to replace?
Hi guys,
I just got my '03 TL a few weeks ago from my grandpa and the one thing wrong with the car is the cruise doesnt work. We have traced it back to the actuator motor. The dealer wants 350$ plus labor. I found the motor for 100$. How hard would it be to do it myself? Has anyone done this?
Thanks,
Alex
Thanks,
Alex
Super duper easy?
Housing is bolt on into a metal bracket with 4 Philips heads and the bracket itself is hold by 3x10mm bolts.
To remove the Actuator line you just need to remove 1 Philip Head holding a Little bracket into the motor. To remove the Metal Line from the Cruise actuator just with your left hand turn the actuator (Since its spring loaded) and remove the metal line from it with your right hand = DONE < Reverse Procedure to Install.
EDIT: Forgot to unplug and plug cables but thats pretty obvious.
Hope that helps.
Hope that helps.
Super duper easy?
Hope that helps.
Hope that helps.
Very simple.
mada51589
Jan 9, 2025 04:40 PM
cycdaniel
Dec 17, 2019 10:58 AM
spoiler900
5G TLX Photograph Gallery
Sep 11, 2015 09:39 PM
