Crank no start
Old 04-11-2024, 08:20 PM
Hartemisio's Avatar
Crank no start
In need of help please. I have a 2003 tl-s that is crank no start. New cam and crank sensors. Three different pgm relays. New ecu with immobilizer and key. Has no codes. Fuel pump comes on. No spark.
Old 04-12-2024, 02:30 AM
Jon M's Avatar
Do you have a copy of the service manual? When you have the key in the on position do all of the dash board light come on?
Old 04-12-2024, 04:56 AM
Hartemisio's Avatar
No I do not have a service manual. I have wiring schematic for starting and engine. All the lights come on.
Old 04-12-2024, 12:20 PM
Hartemisio's Avatar
I forgot to mention that I do have power and ground to coils. The rpm’s gauge never moves while cranking.
Old 04-12-2024, 06:14 PM
Jon M's Avatar
Here is a link to the manual. You mentioned you replaced the CAM and Crank sensors, did you replace the timing belt? Was the car starting before you did the replacements?
LindaLee0609 (05-04-2024)
Old 04-12-2024, 09:47 PM
whitetiger5's Avatar
Do you have a DTC reader? gotta be something coming up there.
Old 04-13-2024, 06:15 AM
Hartemisio's Avatar
I do. There are no codes.
Old 04-13-2024, 08:04 AM
Hartemisio's Avatar
Sorry I did not see the other post. The car was a crank no start when I bought it. The car is in time with good compression. Engine is in time with new crank and cam sensors. No codes. Power and ground to coils. Fuel pump comes on. Tach does not display rpms while cranking.
Old 04-13-2024, 08:18 AM
John from PA's Avatar
Puzzling, “power and ground to coils” and “fuel pump comes on.” What about presence of fuel after the pump?
Old 04-13-2024, 08:53 AM
Hartemisio's Avatar
Is there a Schrader valve to check for fuel? No rpm on gauge is weird. No spark.
Old 04-14-2024, 07:01 PM
Jon M's Avatar
There is no valve for fuel. There are two fuel rails. One has a regulator at one end and a pulsation damper where the fuel line come into the fuel rails. Check the manual.
Check page 4-15 of the manual and you can see the power for spark comes from the ignition to a 15A fuse under the dash (#11) and then to the coils. The coils need pulsed by the PCM if the PCM isn't there or isn't powered there will be no spark. The PCM gets it's power from the PGM main relay. Check to see if the PCM is there and powered. If the PCM is bad there could be no tach, it computes the speed from the crankshaft position sensor, there would also be no spark.
Old 04-14-2024, 07:55 PM
Hartemisio's Avatar
The pcm is there. I can read codes and it has none. It has fuel to the rails. I’m pretty sure the injectors are not firing either. I have tried pcm reset as well.
Old 04-14-2024, 09:35 PM
Jon M's Avatar
The only codes you might be able to see is if they were stored codes. The OBDII system only reads stored codes; unless the car is running. In your case it is not proof that the PCM is working. Have you downloaded the manual?
Old 04-14-2024, 10:03 PM
Hartemisio's Avatar
Yes I have downloaded the manual. Thanks for that. I read through it but didn’t see anything to help me I feel like. Like I said. It has no spark no injector pulse no rpm on gauge.
Old 04-14-2024, 11:54 PM
Jon M's Avatar
Go to the manual, search for DTC there is a troubleshooting procedure for not stating. Since your have seem to have a good battery, you need to move step by step and the manual contains EVERYTHING. It will not tell you what your problem is, it will tell you how to test things and what they do (you have to think about what they say and how it applies to your circumstance). There are multiple sections for troubleshooting and for no start you should check the PGM circuit, use page 11-160 to start, after checking the fuse in the diagram below. If the fuse is OK measure the voltage it should be battery voltage voltage and the battery should be at least 12.6 vDc.
Check this fuse with a DVM. ALWAYS use a DVM to measure a fuse, I have seen fuses measure 100k ohms with no indication it was blown. All fuses should be 0 ohms.
Old 04-15-2024, 12:05 AM
Jon M's Avatar
Additionally the diagram below is the whole ignition circuit (page 4-15). Take a look at page 4-9.
Trace the voltage to the coils, make sure the ground by the starter is good, actually feel and look closely. If all is there then the inputs from the PCM are missing and you will need to try to capture the pulses on a DVM or O'scope.
The pulses are only there when you crank the Engine and the PCM is good.
Old 04-15-2024, 11:53 AM
Hartemisio's Avatar
I will recheck the voltage on the fuse 13 tonight. Everything checked out last time other than the signal.
Old 04-15-2024, 05:19 PM
Hartemisio's Avatar
So the blue/orange wire at the relay has 0v key on and 5v cranking.
Old 04-15-2024, 06:18 PM
Jon M's Avatar
I am not sure the diagrams are drawn to detail and I don't know if a resistor is in line I am not totally sure of what the voltage should be. However according to the diagrams there should be 12v at the fuse. According to the table below the blue/org wire should have battery voltage. The way I would proceed is to measure the voltage coming off the ignition switch (blk/wht wire) it should be 12 vDc. If so I would replace the starter cut relay. If the voltage is not 12v on blk/wht wire I would replace the ignition switch. One more question, does the green key indicator on the dash come on and go out when you turn the key to the on position?
See number 24 Blu/Org wire
Old 04-15-2024, 06:53 PM
Hartemisio's Avatar
5v on the black white wire. The light comes on and goes off.
Old 04-15-2024, 07:31 PM
Jon M's Avatar
Look at pages 22-190,191 etc. Unfortunately they don't tell you the expected voltage but I would expect 12v. I would replace the ignition switch. Those pages I just mention have additional tests.
Hopefully others will chime in here but if I remember correctly (and you can search the forum) several people have had problems with the switch.
Old 04-15-2024, 08:13 PM
Hartemisio's Avatar
I will get an ignition switch tomorrow. I did read that it was a known problem.
Old 04-16-2024, 06:36 PM
Hartemisio's Avatar
The ignition did not work
Old 04-16-2024, 06:52 PM
Jon M's Avatar
I assume the immobilizer was not out. As I was recently reminded in another thread, by Whitetiger 5, if the transmission range switch is not aligned properly the car will not start. Search the PDF manual for the Transmission Range Switch.
You can rotate the control arm shaft a bit each way. If the car doesn't think it is park or neutral the car won't start.
2nd page. pages 14-383,384
Old 04-16-2024, 06:56 PM
Jon M's Avatar
FORGET THE TRANSMISSION RANGE SWITCH FROM MY POST ABOVE. If it was the Transmission Range Switch it would not allow the car starter to turn over.
What parts in the ignition did you replace and did you remeasure the voltage?
what number parts did you replace.
Old 04-16-2024, 07:30 PM
Hartemisio's Avatar
The ignition switch. Sorry I didn’t type it.
Old 04-16-2024, 07:44 PM
Hartemisio's Avatar
Same 5v on the black/white wire from ignition switch
Old 04-16-2024, 08:26 PM
Hartemisio's Avatar
P
Pin 2 on left hand side only has 5v. I don’t understand how that would keep it from starting since it is cranking.
Old 04-17-2024, 07:57 AM
Hartemisio's Avatar
I verified fuse 13 has battery voltage. I cut the blue/orange at the relay and the fuse box to install a new wire. Still 5v
Old 04-18-2024, 01:54 AM
Jon M's Avatar
I am a little confused as you said the blu/ org wire had 5 volts yet now you had battery voltage between the fuse and ground. Electrically these are the same points so you must be measuring them differently. For example if you are measuring the voltage at the fuse on side other than side that the wire goes to the PGM relay and PCM. Or you measured the voltage at the fuse with the blu/org wire cut . So there are two possibilities I see with the information so far:
1. The fuse is partially blown. Did you measure across the fuse with an Ohmmeter (on ohms, key out)?
2. The PCM or PGM Main relay or something connected to them, has a partial short and causing the voltage to drop. The battery would be trying to supply the 12v at X current, with a partial short (damaged part) the battery would be trying to supply the 12v but the current demands (now XX) of the short are too much for the battery and the voltage it can provide will decrease.
I am still not sure what piece you replaced for the ignition. It should have been the part below (#8 or the entire assembly #1 or #2) Measure the voltage on the Black/ White wire coming from the ignition switch going to the fuse box. Then pull the #13 fuse and remeasure, both measurements need the key being turned all the way on. Record both voltages. If it is battery voltage when the fuse is removed then the ignition switch is Ok. If it is 5v when the fuse is removed then the ignition is bad. If it is 12v when the fuse is removed and 5v when the fuse is put back then something has gone resistive and the problem is 1 or 2 above.
bigdrew18
2G CL Problems & Fixes
04-14-2024 04:34 PM
nicole _walter
04-28-2021 08:49 PM
Knight Rider 357
08-21-2019 07:35 AM
bgruhn76
09-13-2016 12:16 PM
ericcdong
04-01-2016 08:58 AM
Quick Reply: Crank no start
