coolant question
Old Apr 7, 2013 | 11:58 PM
hondakid23's Avatar
coolant question
The other day I popped my hood to put my battery cover i forgot to put on last week and the coolant reservoir tank looked low, I opened it up and it was completely empty, I usually check it dont know how long its been like that def has to be less than 1 week but still not good So i filled it up to the max line and about 4 days later its halfway down..is this normal i dont see any leaks and theres no puddles when i park my car overnight or when i start up and let it warm up no dripping or nothing...What can this be?
Old Apr 8, 2013 | 06:53 AM
fsttyms1's Avatar
Take your radiator cap off and make sure the coolant level is full in there. If it is top off the coolant overflow tank and just check it to make sure it isnt going low.
Old Apr 8, 2013 | 08:35 AM
3.2TLc's Avatar
If the coolant continues to go down for no apparent reason.....then a pressure check of the cooling system may be in order to help detect a leak.
Old Apr 8, 2013 | 11:06 AM
hondakid23's Avatar
appreciate it, I just took off the radiator cap and topped it off and I am going to check how long it will take the reservoir tank fluid to go down.
Old Apr 8, 2013 | 04:48 PM
3.2TLc's Avatar
So how low was the rad's level ? Was the fluid normal in appearance ?
Old Apr 8, 2013 | 06:13 PM
hondakid23's Avatar
Yeah looked normal usually how long would it take for your coolant to get low like that in the reservoir tank?
Old Apr 8, 2013 | 09:27 PM
fsttyms1's Avatar
It should really never get low, unless you have a leak or the engine is consuming it.
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
LeVeL
Oct 18, 2015 04:19 PM
ROSSARONIE
Oct 2, 2015 11:46 AM
Username 0
2G TSX Performance Parts & Modifications
23
Sep 28, 2015 09:09 AM
