Coolant leak.dont know where its coming from. HELP
Old Oct 20, 2013 | 07:47 PM
Acira's Avatar
pTTp
Alright,so my car is leaking coolant only a little bit though once i turn the engine on,and have no clue where its coming from. The stealership wants to charge me 115 dollars just to diagnose it. My question is should i go to the dealer or take it somewhere else to maybe get it cheaper?Opinions needed. Gracias.
Old Oct 20, 2013 | 07:49 PM
Skirmich's Avatar
Try to pinpoint yourself? ITS FREE!
Possible: A/F tubes, Thermostat, Sensors and finally water pump..
Old Oct 20, 2013 | 08:09 PM
Acira's Avatar
pTTp
Im actually doing that right now but didnt know where to look. Hope i can figure this shit out before hand. Im going to pinpoint those. Skirmich youre dope and a big help.Thanks.And how expensive could a fix get?
Old Oct 20, 2013 | 08:32 PM
Skirmich's Avatar
Depends on what is wrong? Just cross all fingers is not your water pump cuz that is going to get SICK EXPENSIVE.. Everything else is completely DIY and cheap.
Old Oct 20, 2013 | 08:48 PM
Acira's Avatar
pTTp
Ight souns good. I just jacked up the ack. Im about to try and figure this out. My fingers are crossed.
Old Oct 20, 2013 | 10:31 PM
Yikes's Avatar
When you look at the spot on the ground, where does it seem like it's dripping from relative to the engine? Front? Side?
Old Oct 20, 2013 | 11:08 PM
Acira's Avatar
pTTp
Well i was going to look under but i had to put it back down and go take care of some business but anyway it seems to be leaking would say under where the dashboard is in the middle. Idk exactly where.
Old Oct 20, 2013 | 11:12 PM
Yikes's Avatar
I'd have to take a peek under my hood to say for sure, but that sounds like a maybe a coolant hose that leads to the heater core might have a hole or might be leaking.
I know when the heater isn't turned to hot, coolant isn't flowing through the heater core, but I'm unsure if coolant flows through those hoses regardless of where the climate control is set to.
Old Oct 20, 2013 | 11:36 PM
Acira's Avatar
pTTp
Yeah idk for sure either but ima check it out tomorrow because i got to figure this shit out fast. But o just hope its not my water pump,thats noo bueno.
Old Oct 21, 2013 | 12:49 AM
Chillbill's Avatar
5th Gear
Follow the hoses and look for areas where the coolant has dripped down. Check the condition of the hoses. Best of luck, hope it isn't your heater core or water pump. Radiator and hose fixes are a lot simpler.
Old Oct 23, 2013 | 07:57 PM
Acira's Avatar
pTTp
Question Went under and still cant tell.
Ok,so i went under and looked and all i found was a trace on my oil pan leading up to the front of the oil pan in between this litttle ass crack and i cant tell from there.I cant tell from the top or the bottom.If anybody has an idea of some kind what it is i very much appreciate it. Thanks aziners.
Old Oct 23, 2013 | 08:07 PM
Acira's Avatar
pTTp
And idk if this is possible but it seems to be seepig out of my oil pan where the bolts hold it together. I think im in trouble.
Old Oct 24, 2013 | 07:03 AM
3.2TLc's Avatar
Question coolant leak......?
Hey Acira, try first cleaning up the undercarriage of the front motor area. Then run the car up to operating temp, turn the motor off and place a large piece of cardboard under the motor.
Leave it cool down and sit for a few hours, then check for where the drip's located at on the cardboard. This will give you an idea of the general vicinity which the fluid may be leaking from.
Trace the residual fluid trail back up to it's source. If it's coolant, check obvious hoses and clamp fittings. May have to remove the top motor's cover to get in for a closer look with a flashlight. Check the heater hoses as well near the rear firewall.
If this doesn't help. then get a new piece of cardboard and turn on the motor and let run. Some leaks will only happen under pressure. Just be careful of getting underneath or in close to the motor while it's running !
Old Oct 24, 2013 | 07:43 AM
fsttyms1's Avatar
Its not leaking there. Its running down and the oil pan/block seam is causing it to slow and show there. Is it on the side where the belts are?
Old Oct 24, 2013 | 02:02 PM
Acira's Avatar
pTTp
Yup,its on the crank pulley side. But just like you said the pany/block is in the way.
Old Oct 24, 2013 | 04:23 PM
Yikes's Avatar
That makes the water pump even more suspect. Pull the lower timing cover off and get back to us.
Old Oct 24, 2013 | 06:06 PM
3.2TLc's Avatar
leak....
So, the leaking coolant appears to be more evident on the passenger's side of the motor ? Be sure to eliminate any possible hose leaks which may eventually drip down the side of the block to the lower pan area.
If it's indeed the water pump ...... the leak should be more evident at the bottom T-belt cover area on the block's LHS. Wipe the area dry and check it closer. How much coolant are you losing ?
Old Oct 24, 2013 | 09:26 PM
Acira's Avatar
pTTp
Yeah on the passenger side and im barely losing any coolant and my car isnt over heating.But ima look closer,i got to.I dont think its easy to remove the lower timing cover. Is it?
Old Oct 24, 2013 | 09:50 PM
Yikes's Avatar
It isn't too difficult. When you get under the car there is a plastic shield. There are a hand full of plastic clips you need to remove. You can use needle nose pliers, or use the tool they make for it. Be careful though, you might break one or two. If you do, it isn't a big deal.
Fold the cover aside and there is (I think) 3 or 4 bolts that you need to undo to get the lower timing cover off. Again, not sure on the number of bolts but there aren't that many.
Old Oct 24, 2013 | 10:42 PM
Acira's Avatar
pTTp
Alright ima try that for sure cuz the stealer ship is full of shit.lolBut after I'll get back ASAP.Man,for real,I really appreciate all the help and input from all of you. Much is gracias.
Old Oct 24, 2013 | 10:53 PM
Yikes's Avatar
No problem. Sorry I couldn't help out more by providing you with pictures.
As for the dealer... doesn't surprise me. They seem like they're always trying to increase the amount of billable hours for the service department.
cycdaniel
Dec 17, 2019 10:58 AM
merc009
Jan 27, 2016 10:34 AM
1lowtc
1G RDX (2007-2012)
15
Nov 19, 2015 10:52 AM
01CLOwner
Oct 9, 2015 01:07 PM
