Coin / Ashtray Removal
Old Aug 23, 2007 | 04:26 PM
PaulTX's Avatar
I have a 99 TL. About three years ago coins got stuck behind the coin tray preventing it from closing. While at the dealer for other reasons, I mentioned it and the service rep said no problem, we'll fix it. The service rep said there is a simple trick to removing the coin tray and offerred to show me. I rushed off without learning the trick and he is no longer there.
Well, it has happened again with coins stuck behind the tray preventing closure.
I searched the forum and people talk about removing panels around the shifter to get to the coin tray. This is certainly not the simple trick I was looking for. I figure folks must be talking about a different model or year. My flip down coin tray is directly under the radio which is pretty far away from the shifter. Can some one help me?
PaulTX
Old Aug 23, 2007 | 04:55 PM
fsttyms1's Avatar
i havent seen any other way
Old Aug 23, 2007 | 05:13 PM
SatinSilverTypS's Avatar
ChairmanMaoSaysRTFM
removing the whole center console and cointray literally only takes 5 minutes at most. it's not that big a job at all. there are other tutorials on the forum of how to do it so i'll spare you my crappy instructions, but it's definitely not that big a deal to do it.
Old Sep 15, 2007 | 12:35 PM
jimd's Avatar
6th Gear
I have a '03 TL and the ashtray power outlet is loose and rattling all the time. I was wondering if it's similar to your location and if you found an easy way to access it? It appears to be a major job to get at it. Any ideas?
Old Sep 15, 2007 | 01:49 PM
fsttyms1's Avatar
you have to go about it the same way. its really only a 5 min job
Old Sep 16, 2007 | 11:02 AM
youngacuraowner's Avatar
6th Gear
I have a 02 TL Type-S and and i'm having the same problem, can someone provide a link on how to remove center console????
Old Sep 16, 2007 | 04:19 PM
acuratech25's Avatar
actually if you remove the cover for the dlc under the coin holder you can take a screw driver and slide the coins out of the way but you might not be able to collect all the change some will fall down
Old Sep 28, 2007 | 08:36 PM
Fossil_TL's Avatar
please someone post up an instruction.
Old Sep 29, 2007 | 06:11 PM
Fossil_TL's Avatar
yeah I took it all apart today, but the easiest way to fish out coins in to remove the "L" shaped plastic flap under the coin tray.
Old Sep 29, 2007 | 09:47 PM
Bob_F's Avatar
Here's a helpful "how-to" with photos:
http://www.skyeflye.com/acura_cls/In...01-2003_CL.pdf
This is for accessing the radio but the initial steps are the same.
iRaw
ILX Photograph Gallery
30
Aug 5, 2016 04:41 PM
dainmezron
Oct 16, 2015 06:56 PM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
ROWDY621
Sep 30, 2015 03:20 PM
lowgrowl
Sep 26, 2015 05:18 PM
