Clicking when try to start not battery or starter
Old Aug 23, 2011 | 01:12 AM
RichInUT's Avatar
4th Gear
I replaced the battery, cleaned the cables and now replaced the starter. Still clicking when I try to start. I also notice a click when I turn the key to the on position first (coming from what sounds like right underneath the center air intake) and then I try to turn it over i get the click click click etc..... Could this be related to an ignition switch or a bad key? I also notice the little green key icon on the dash flashing when I try to start or is that normal???? Thanks for any help
Old Aug 23, 2011 | 08:11 AM
fsttyms1's Avatar
is the clicking coming from the starter? The clicking is usually a indication of not enough power from the battery.
Old Aug 23, 2011 | 11:40 AM
Gee702's Avatar
could be bad ignition switch. ive changed alot of accord ones so far
Old Aug 23, 2011 | 12:35 PM
01tl4tl's Avatar
Is this a 99? then I would suspect key issues- are there several keys on your keyring? weight is bad
even new battery can be very low on charge
what about a jump start- what happens then?
neg cable contact to ground of frame/engine is clean?
cant just throw on new cables, need shiny metal to shiny metal contact- even clean the new cable ends for max contact
Old Aug 24, 2011 | 02:39 PM
RichInUT's Avatar
4th Gear
Cables looked good but still changed out all the negative ones and starts fine now.. Thanks for your suggestions its a 2003 TLS btw..
mada51589
Jan 9, 2025 04:40 PM
Feb 25, 2020 09:57 AM
obert
Dec 14, 2015 11:36 PM
gemz_acura
4G TL Problems & Fixes
15
Sep 26, 2015 06:12 PM
jordanboi
Sep 5, 2015 01:33 AM
