Clicking sound when air system is on
Old Oct 21, 2011 | 11:36 AM
cleardevil's Avatar
Hi, on my 2000 TL, i get a clicking sound whenever the air system is on (heat/AC). It sounds like its coming from under the glovebox area near the foot area of the passenger seat. Anyone have any ideas?
Old Oct 21, 2011 | 11:46 AM
01tl4tl's Avatar
sounds like something got inside the vents and is next to the blower motor
changed the cabin air filter? part runs from 12 to 20 bucks for a box of 2 filters,
they sit side by side in a plastic tray next to the blower
easy diy
see master diy list https://acurazine.com/forums/2g-tl-1999-2003-98/new-official-2nd-gen-tl-diy-thread-706083/
save that link to favorites- its your new best friend
note no need to use dremel to cut the tabs (assuming job never done before)]
kitchen scissors cut thru fast
and welcome to acurazine!
Old Oct 21, 2011 | 11:47 AM
01tl4tl's Avatar
most find a mass of crud- need shop vac to get it all out
Old Oct 22, 2011 | 02:25 AM
my.daily'tl''s Avatar
Always Working In
Air mix motor. The arm on it usually jams. Passenger side in engine compartment directly ahead of glovebox look for a thin cable going to the small about 1" heater hose. Spray some lube and work it around see if that helps loosen it up.
Old Oct 22, 2011 | 10:06 AM
Diva 4 Life's Avatar
99Ackrite
I done that also on mine, seemed to help.
Old Oct 22, 2011 | 11:32 AM
01tl4tl's Avatar
sounds like something to add to the diy,,Lube heater core valve operating arm!!
same for throttle cable return springs at TB
Feb 25, 2020 09:57 AM
mnodaddy
5G TLX Problems & Fixes
Sep 20, 2015 12:14 AM
Iain MacLeod
Sep 17, 2015 01:01 PM
cak165
1G TSX Problems & Fixes
Sep 16, 2015 08:17 PM
sputik
Sep 7, 2015 01:40 PM
