rough acceleration ?
Old Oct 19, 2011 | 03:30 PM
tomf's Avatar
03 Type S - 153,000 miles
03 tl type s - 160k miles, plugs done at 150k miles ngk iridium, seafoamed a few months ago, intake, gasoline etc. change oil every 3000k miles. K/N air filter cleaned about 10k miles ago.
The car at lower rpm's under light acceleration pulsates ( rpm jump) about 200- 500 rpm ( anything under 2500rpm) especially when under 2000k rpm. I noticed today while in park, when I rev the engine - there is a rough feeling ( kind of grainy ??) Never felt the car like that before, normally very smooth when I rev the engine. 3rd gear is also giving me some issues as well, hesitation and sometimes a slight shutter just before it shifts.
Could it be a vacuum leak from a bad engine mount ? Plugged egr ports ( but wouldnt the engine run really rough, and throw a code ?), Idle control valve ? Do the valves need to be adjusted ?
I'm not all that mechanically inclined, but dont want to spend a ton of money to find the issue. If there are any home tests i can try, i would love to pin point the issue.
Oh, I have never manually cleaned the egr ports out, and always run premium fuel.
Old Oct 20, 2011 | 09:48 AM
fsttyms1's Avatar
Have teh mounts ever been changed? A good place to start would be by cleaning the TB, IACV and run a good fuel cleaner thru the fuel system like Seafoam. You could also seafoam the motor thru a vac line.
Old Oct 23, 2011 | 03:37 PM
tomf's Avatar
Mounts have never been changed. Ran seafoam thru system last month per diy thread on site. Gas ,vac line,cleaned tb plate etc.
Old Oct 23, 2011 | 05:32 PM
01tl4tl's Avatar
noobs to seafoam should repeat after a month or so to finish off the last of the crud,
then good for a year
sounds like egr passage plugged to me
160kmiles,, may as well adjust the valves once you are halfway in there doing egr
At least a few to several will be off spec,, and valves are set right,, or they are not
Mike734
Dec 10, 2021 01:25 PM
mlody
Dec 4, 2019 02:11 PM
joflewbyu2
Aug 18, 2019 10:38 PM
copmagnet82
4G TL Problems & Fixes
Jun 29, 2016 08:09 AM
xsilverhawkx
Oct 5, 2015 11:00 AM
