Clicking noise?
Old Jul 16, 2007 | 01:28 AM
SSM 03 Type-S's Avatar
Clicking noise?
Have an 03 TL-S with only 38K on it and i'm noticing a clicking or gargling noise coming from the motor under acceleration, anywhere from 5% to about 50% throttle. Sometimes more apparent when going up hills. Hard to explain the sound. Just wondering if anyone knew what this was or has the same problem?
Old Jul 16, 2007 | 02:51 PM
bibledriver's Avatar
Something is missing...my
Sounds as though it is worse when under a good load. Could there be an exhaust leak?
Mine was doing that too, and the resonator was bent. After I installed the headers, the problem was gone. I think one of the little crush gaskets wasn't sealing well.
Have you put any exhaust mods? Maybe created a slight leak?
Old Jul 16, 2007 | 02:52 PM
SGVxGHOSTx08's Avatar
Usually on 2nd gear or 3rd??
I think i have the same problem too but don't know where it is coming from.
Old Jul 17, 2007 | 10:37 PM
I havent done any exhaust mods to the car. And yes it is in second and third gear. I just dont have any clue what it is an i really dont want to take it to the dealer because its out of warranty
Old Jul 18, 2007 | 04:40 PM
It does sound similar to mine before I replaced the gaskets in the exhaust.
However, there are about a thousand things that can click.
Is it worse when you go over bumps or turn?
Is it definitely from engine bay?
gargling? what's that (kinda what made me initially think of exhaust)?
Old Jul 19, 2007 | 01:30 AM
Its definitely from the motor. it sounds like there is something in there just bouncing around. When i go up a hill i can hear the motor clicking. I dont know how to describe it other than that.
Old Jul 19, 2007 | 08:28 PM
what kind of fuel do you use?
Old Jul 19, 2007 | 09:44 PM
01tl4tl's Avatar
Calling Captain Seafoam, page for Capt Seafoam
Old Jul 19, 2007 | 10:07 PM
Always premium, which is 92 octane around where i live
Old Jul 20, 2007 | 01:01 PM
yeah, if you haven't, might seafoam it just for good measure. Kind of vague symptom. Does it change with rpm, is it separate. Rattling around or valvetrain-like?
Old Jul 20, 2007 | 01:45 PM
01tl4tl's Avatar
Or perhaps an idler pulley or ac compressor gone bad?
Old Jul 20, 2007 | 11:01 PM
Its usually at lower rpms. Its apparent when starting from a dead stop or going up a hill.
Can small rock chips or small particles get inside the intake and be inside the throttle body? It just sounds like there is something bouncing around part of the motor when its under half throttle or less.
Old Jul 23, 2007 | 02:00 PM
well, if it is something bouncing around, I would think maybe a bolt or something. don't think so on the dirt in intake, though.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
SexyRL
4G TL Problems & Fixes
Aug 19, 2016 10:03 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
thegipper
Sep 28, 2015 01:01 PM
