Cleaned shift solenoid filter screen fixed problem
Old Sep 16, 2014 | 11:24 AM
  #121
mnanda's Avatar
Not that easy but worth the effort
I have a 98 Honda Accord Ex. Took out the solenoid and cleaned it up with a garden hose with sprayer - that cleaned it out like new. Replaced the solenoid, did the drain, fill & drive 3x with Honda ATF DW-1, and added 7.5 oz of Lubegard 60902 after the last fill (available on Amazon or at local Napa auto parts for a little less). The Lubegard is recommended 1 oz per quart of trans fluid.
Someone asked about which to do first - the drain & fill or clean the solenoid. I think it would probably be best to clean the solenoid after replacing the trans fluid. If you don't, then the screens may get clogged up again. Once the trans fluid is fully replaced, most of the gunk should be gone, then clean your solenoid screens and they should not get clogged again.
My results were good enough to make it worthwhile, but not like night and day. My vehicle was hard shifting and this process has smoothed it out somewhat. I've heard though that after changing the fluid and putting the Lubegard additive you should give it 250 miles or so to see improvement. I've driven about 150 and see some improvement, and am hoping for further results as I drive it more.
As far as getting the solenoid out, I got the impression from what I read here that it would not be too hard, though some people here did say it was a P.I.T.A. And man was it so! I don't know if everyone here has the same setup for on my vehicle I had to unplug 9 or 10 electrical connections, unbolt some kind of ground wire, unbolt the wire harness from the back, and remove some bracket held in with 2 huge bolts 6-8 inches long. And the hardest part was trying to undo the solenoid plug. Someone here said it has a hidden clip underneath you have to push up. I could not get it undone at all and ended up just forcing it off and breaking the clip. I had to use a little Gorilla glue to put it back in place.
Anyhow, thanks for all who contributed here. And good luck if you try this. You have a good chance of keeping your tranny going by cycling some new DW-1, cleaning your sloenoid screens & topping off with some Lubegard if you like. I researched this Lubegard and it seems to be one exception of an additive which alot of people recommend including tranny pros.
Wood Flooring by Gemini Floor Services: Installation & Refinishing
Old Sep 17, 2014 | 08:01 AM
  #122
MarcDavidoff's Avatar
I would agree on the lubegard. One additive I believe really works. I had some slight shuddering usually when shifting from 1st to 2nd. I slowly noticed the shudder disappear after about 1k miles or so after adding it
Old Sep 18, 2014 | 11:24 AM
  #123
pstomps's Avatar
I bought a 99 TL with 70k on it before I knew this problem existed. I test drove it after another person, so since it was already warm, the shift flare wasn't very noticeable. Now that it's getting colder, I will get about 1000RPM flare shifting from 2nd to 3rd for the first minute of driving on a cold start. Once it starts to warm up, the flare is only about 250-300 RPM. Also within the first minute of driving, I'll get a delayed hard jerk at a complete stop (seems like a hard drop into 1st for some reason). This symptom goes away completely after about a minute of driving.
I did a 3x3 drain/fill that didn't seem to do much for me. I think the car was originally a lease, so I assume the previous owner(s) never changed the fluid (my first drain was almost black). Based on that drain, I can't imagine that I have clean screens.
So I'm considering buying a new shift solenoid and linear solenoid because if I'm taking that thing off once, I don't want to do it again. Can anyone advise whether or not they think this will help my problems? I don't want to spend $350-400 on parts that won't help me. If the solenoids won't help, I'm just gonna have to dump this car asap and find something that works.
Old Sep 18, 2014 | 06:20 PM
  #124
3.2TLc's Avatar
Welcome Pstomps !!!
A '99 TL with only 70k could possibly be something simply gunked up from neglect, IMO.
If ya done the D & F, then try cleaning some of the solenoid screens. Maybe even check the prices on new pressure switches. Are ya getting any codes or blinking "D" ?
The '99 TL's with the older 4 speed AT were much more durable than the newer 2000 and up 5 speeds.
So, it may be worth spending some effort and money on.
Old Sep 18, 2014 | 06:50 PM
  #125
pstomps's Avatar
Thanks for the advice! The drain plug looked pretty bad when I did the first drain/fill, but I wasn't sure if that was normal if it had never been serviced. No codes or blinking D light, though. The problem seems to mostly go away when the car is warm.
Yeah, the new switches aren't too bad from some online parts sources (about $350 for both switches and screens/filters), but I wanted to see if anyone would be able to give me a more definite diagnosis based on the symptoms so I don't end up spending too much money on switches if my transmission is toast. But I figured I might as well replace them if I decided to spend all the time getting them off in the first place (I tried once, spent a few hours, and didn't get a single bolt off) since it's so much work.
Do you think the switches are prone to failure (especially if the screens get too gunked up...can the screens fail and allow debris in?), or would it be a better idea to just get the $20 screen to make sure it is definitely clean instead of trying to get it clean myself?
Old Sep 18, 2014 | 06:53 PM
  #126
pstomps's Avatar
Drain plug from first drain/fill: https://i.imgur.com/RyUScLj.jpg
Old Sep 18, 2014 | 08:12 PM
  #127
^ that's not too terrible but to me does show that the fluid likely had not been changed in a long time. I would say at least 30k miles or more. What did the fluid look like?
Old Sep 19, 2014 | 06:06 AM
  #128
pstomps's Avatar
It was pretty dark. Almost like old oil, and speckled with some more fine metal shavings.
It's still not completely red after a 3x3, so I'm planning to do one more dran/fill once I get the solenoid figured out.
Old Sep 19, 2014 | 07:26 AM
  #129
3.2TLc's Avatar
Unhappy Rpm flaring up between 2nd & 3rd gear......
I did a 3x3 drain/fill that didn't seem to do much for me, so I assume the previous owner(s) never changed the fluid (my first drain was almost black). Based on that drain, I can't imagine that I have clean screens.
So I'm considering buying a new shift solenoid and linear solenoid because if I'm taking that thing off once, I don't want to do it again. I don't want to spend $350-400 on parts that won't help me.
Make sure that the tranny fluid is at the proper level and check the mounts.
To save money on parts, ya could try removing the shift control solenoid valve "C" and the top linear
A/T clutch pressure control solenoid valves "A-B" pack......then inspect and clean their screens before
re-installing. Also the 3rd clutch pressure switch may be sticking, consider testing and replacing it.
As an cheaper alternative to new "OEM" parts, check other online sources for aftermarket replacement parts.
Old Sep 29, 2014 | 06:57 AM
  #130
pstomps's Avatar
Pulled the shift solenoid this weekend. There was some crud, so I cleaned it off and reinstalled. I also checked the linear solenoid pipes/screens while I had stuff taken apart, but it wasn't too dirty.
Reinstalled, and the problem hasn't gone away. Fluid level is a tiny bit above the top dot when hot. I did the drain/fill 3 times with two weeks between each and had the problem the whole time, so unless it was slightly full each time I'd guess that that isn't the issue. But I could be wrong.
I'm going to take it to a tranny shop on Thursday and see if they can give me any more info whether or not it's a sensor or the clutch packs.
Thanks for the help, everyone! I'll update with the shop's diagnosis next week hopefully.
P.S. unlike some comments say, you CAN (well, almost) get a straight shot with a really long 1/4" ratchet extension. The plastic wire harness thing (the giant thing in the way) has two bolts and a couple zip ties that are clipped in. If you remove the bolts and zip tie clips, you can wiggle it out of the way enough to get a pretty straight shot on both the front and middle shift solenoid bolts. The rear one required a universal joint adapter to get at the bolt from a slight angle. I had to put some electrical tape on it so it would flop over too much.
Old Sep 29, 2014 | 05:32 PM
  #131
3.2TLc's Avatar
^^^ Did ya try manually firing the solenoids by applying 12VDC to them ?
The top linear "A-B" clutch control solenoid's middle tube usually gets blocked off with the same sludge that's found on the pan's drain magnet. Ya may also wanna check the 3rd & 4th pressure switches as they sometimes will go bad. Was there a lot of crap on the magnet ? Did ya replace the spin-on ATF filter ?
Old Sep 30, 2014 | 12:07 AM
  #132
rp_guy's Avatar
'03 ABP YA4-S 6MT
does anyone know which screen this is:
Old Nov 10, 2014 | 05:47 PM
  #133
navajoDDS's Avatar
pstomps, did you ever get your tranny looked at? Mine is doing the exact same thing and I'm curious if you found a solution or have an update.
Old Nov 11, 2014 | 05:39 PM
  #134
3.2TLc's Avatar
Thumbs up Cleaning solenoids.....
Originally Posted by donroyal
Thanks to everyone who has posted. The information has been invaluable. I was able to get my sisters 99tl going again. Had to do it twice cuz the first time I went through the tranny I got the reverse collar in upside down. BAsically I replaced filter and clutches and put it back in. It still had one nagging problem: it would lurch when going into first or second but only when cold. After speaking with several builders and studying the service manual I decided that the problem was in the line pressure control solenoids. One of the builders told me that it is never the solenoids but the screens under them. This is a really easy fix. The line pressure solenoids are easy to get to once you get the battery tray out. They are on top of a plate held in place with six bolts. Once you get them out (one black connector and one brown one) you will notice four pipes sticking up out of the case. The one off to the side by itself is a vent. Ignore it. The other three are easily lifted out with only your fingers. Each one has a small screen in the bottom. They are different lengths but don't worry, they will all protrude the same amount when properly re-installed. I soaked them in gasoline for a few minutes then blew them out with an air gun. The car now runs perfectly. Lesson: Honda transmissions have hundreds of little tiny screens in them. There is one in nearly every passage. CLEAN THEM ALL
hope this helps someone.
Don
Yeppur, this can often help your tranny if it's not already fried !!!
Old Nov 19, 2014 | 07:24 AM
  #135
3.2TLc's Avatar
Question Any updates from tranny shop ???
I'm going to take it to a tranny shop on Thursday and see if they can give me any more info whether or not it's a sensor or the clutch packs. I'll update with the shop's diagnosis next week hopefully.
So, after the tranny drain & fills and cleaning solenoids ........ things didn't improve.
Let us know what the shop tells ya. Thanks !!!
Old Nov 20, 2014 | 08:50 AM
  #136
ErickUa5's Avatar
Mr.Helpful Diagram
Thats for the pressure control valve C, I think its used for the torque converter on the 5 speed trans.
Saw the same on mine when rebuilding it.
Old Nov 20, 2014 | 08:57 AM
  #137
3.2TLc's Avatar
Hey ErickUa5, by chance ..... would ya be able to show or describe the location of the above
"pressure control valve C" ???
By the looks of that screen, this would be definitely something to try cleaning on our 2nd Gen trannys.
thanks
Old Nov 29, 2014 | 03:58 PM
  #138
3.2TLc's Avatar
Anybody else that may know the location of this solenoid valve ?
Old Dec 1, 2014 | 08:41 AM
  #139
03TLSinCO's Avatar
I had a similar problem (RPM flair between 3rd & 4th to start, then 2nd & 3rd and finally problems when driving in D5). Drove in D4 for about a week while determining what shop would do an AV6 swap for me and sourcing a transmission. Shop told me it was the torque converter. New AV6 is installed and running just fine.
Old Dec 1, 2014 | 08:52 AM
  #140
ErickUa5's Avatar
Mr.Helpful Diagram
Sorry 3.2tlc its now that I check this thread here you go.
Its right by the ground connection from the battery to the trans.
Old Dec 1, 2014 | 10:42 AM
  #141
3.2TLc's Avatar
^^^ Thanks ErickUa5 ......"Mr.Helpful Diagram" !!!
Old Dec 31, 2014 | 06:42 AM
  #142
alperez's Avatar
Hey. Well on my 2000 tl wen I start to drive wen is cold it drives normal. Goes in to every gear normal, but wen I come to a stop sign or red light it goes in to neutral then goes in gear hard. So what I do is befor it goes back to gear hard I'll put it in neutral then go into gear that way it won't fuck up the gears. It would do it for like 2-5 min of driving, then everything goes back to normal. Will me cleaning the screen help me out on this problem?
Old Oct 7, 2017 | 10:34 PM
  #143
BurritoStrafe_'s Avatar
I know this post is old but anyone else have trouble getting the side solenoid off? I got the top one off but the one on the side is hard. help?
Old Jun 11, 2019 | 04:30 PM
  #144
djskins's Avatar
4th Gear
Hello, I own a 2005 Acura TL and after pulling the 6 bolts to the solenoid it won’t pry loose, any suggestions? I tried to use a screwdriver but it won’t budge. Please help.
Old Jun 11, 2019 | 04:41 PM
  #145
tap it with a mallet
Old Jun 11, 2019 | 07:35 PM
  #146
djskins's Avatar
4th Gear
I Got it off thanks, cleaned the screens after I pulled a code p0700 with a sub code of to-3 and I saw this and some videos about cleaning solenoid As helpful. I think I’ll recheck codes and then if it’s still showing I’ll clean solenoid c or what I see is also called the clutch pressure control valve. Any suggestions on how to get rid of this particular code? Other than these two? I also got a po-848 code with sub code 26-4 Also with the description 3rd pressure switch open or stuck. Which is weird, I just had the 3rd and 4th switches changed 6 months ago. But I’m going to order another and just replace it again. Does anyone know what those sub codes refer to specifically and/or suggestions would be great thank you.
Old Jun 12, 2019 | 11:41 AM
  #147
djskins's Avatar
4th Gear
After cleaning solenoid A screens and topping off about 8OZ of atf and rechecked the codes they both disappeared. So I don’t have re order that switch again yey! If anyone has any questions on my diy let me know.
Old Jun 19, 2025 | 03:43 PM
  #148
Starlight45's Avatar
4th Gear
Reply to PO730 code
Originally Posted by edinjersey
BTW, this is an awesome post! Just tried it and it seems to work so far. That 3rd bolt is a killer-you need a long 10mm wrench or maybe small hands to turn since it's hard to get a socket on it.
I had the same problem-my transmission wasn't catching 2nd or 3rd gear until warm-revving like it was shot but then it would seem to get better after a while of driving. Had a P0730 code for improper gear selection. One thing, after taking off the solenoid, i wasn't able to get the screen completely off-the outside rubber ring was easy enough to pull off but the screens and circular inside rubber rings looked like they might tear. got the assembly w/2 wires disconnected from the other connector and cleaned out the clogged screens with some paper towel-one screen was completely blocked. Now I'm back in business!
response to this post above...
Hello there!! :-)
I just bought a 2000 Acura 3.2TL & after 6 months at 94k the engine light is on. OBD reads po730.
Due to high labor cost, I am learning to do alot of mechanical work on my own. Yes, I'm a girl, but always had the ability to work on electrical parts having a brother who built bikes & motorcycles growing up, I love these things. But,
my problem is this 2000 model has 5 speed automatic overdrive tranny, and I can't find anything that tells me where to locate the shift selinoid? If you still read this post or anyone else can help out, I could use some info. AND advice. I'm not sure if it can be accessed from under the hood, or if under car in tranny valve?? The tran.pan would need to come off, etc. Ty so much for reply!
Old Jun 21, 2025 | 05:21 PM
  #149
whitetiger5's Avatar
Hi @Starlight45 the best place to start is the service manual. you can find links to the pdf version here in the forums if you search for "99-2003 service manual." there are a few different shift solenoids, and a few different clutch pressure solenoids. Keep in mind, the service manual is helpful if you catch a problem early on (most do not) and they tend to take a blanketed "replace everything" when it comes to transmission shifting.
If the behavior is not consistent; you might want to check the youtube video another member posted regarding cleaning of the clutch pressure solenoid ports (there are small inserts with screens that accumulate clutch material). this is probably indicative of a transmission not maintained. This generation acura requires consistent fluid and semi-regular filter changes for optimal performance.
Lastly, you could also just be the inheritor of a TL that wasn't driven often and it could be a design flaw that just hasn't surfaced because of the low mileage. If that's the case, your best option would be to replace it with a BAYA transmission; there is a HUGE thread on that in the top of the 2G forum.
whatever route you go, it's always helpful to come back here and report the final outcome.
Edit: if you check post 140 above it shows a diagram of the solenoid locations. most cost effective route is clean the clutch pressure solenoid screens, replace fluid and re-inspect.
FlopMeister
1G RDX Problems & Fixes
May 18, 2022 11:05 AM
Mike_TX
5G TLX Problems & Fixes
33
Jun 30, 2015 09:58 AM
myisanog
1G TL (1996-1998)
20
May 29, 2010 09:37 PM
disgruntlednut
2G CL Problems & Fixes
22
Jan 10, 2009 11:33 AM
buiyahkah
Aug 17, 2005 11:13 AM
