something seems wrong
Old May 19, 2010 | 01:54 AM
myisanog's Avatar
ok so heres the dealio .
i seafoamed the car about 2 days ago, just drained the atf and put a new screen in today. car was running like a champ for the first couple minutes, i couldnt even feel the car shift gears. but as i was driving to and from work, when my car shifts from 1-2, it would have a major lag. its as though i am stepping on the clutch and still gasing and take 1 second to shift it from 1st-2nd (sometimes its smooth sometimes its a major lag to shift). so basically the car would take FOREVER to shift from 1st-2nd, everything else shifts very smoothly.
and also before i drained the atf, the car would shift between 2500-2800 rpm, but now my car shifts around 1500 rpm, no idea if its normal or whatnot
does something sound wrong?
Old May 19, 2010 | 11:11 AM
DAiNiUS's Avatar
From what I hear with seafoam it either helps a lot or screws up a lot - VERY mixed reviews.
Normally gears shift depending how aggressively you accelerate. So with your normal driving it used to shift between 2.5-2.8k RPM but now that you have this weird 1-2 shifting problem you might be getting a little paranoid; therefore accelerating slower than usual and thus the gears shifting at a lower RPM. This is just my theory.
BTW, how many miles does your car have?
Old May 19, 2010 | 11:37 AM
myisanog's Avatar
138,xxx . i never noticed anything after i seafoamed it, but it actually started happening right after i changed the tranny screen
Old May 19, 2010 | 12:13 PM
desired_speeds's Avatar
your tranny might be slipping. You have to make sure it is seated correctly. I opted for an aftermarket filter and thought mine was really smooth but it ended up slipping. I'd check your fluid level first though.
Old May 19, 2010 | 12:19 PM
myisanog's Avatar
fluid level is good. im going to give it about another day or 2 of driving and if problems continue, ill have to throw a for sale sign on it (i was supose to a month ago but never did), dont have the cash for a new tranny
Old May 20, 2010 | 01:23 PM
KaMLuNg's Avatar
check the fluid level again... it has to be spot on... sometimes if you overfill the fluid, it will also slip like if you don't have enough fluid...
and wait - did you seafoam your tranny or the engine?
Old May 20, 2010 | 02:05 PM
9632tl's Avatar
Radical Member
How are you checling the fluid?
The owners manual says to park the car on level ground, shut it off, and tgen check the fluid.
It doesnt say if the engine should be warm, which seems weird
Old May 20, 2010 | 03:22 PM
TLin401's Avatar
'13 Hyundai Sonata
He seafoamed the engine.
Old May 24, 2010 | 01:58 PM
myisanog's Avatar
i seafoamed through the pcv about 3 days before i changed the tranny fluid . the fluid is a little over the max .. but barely . maybe i should drain and fill again and see how it runs?
Old May 24, 2010 | 01:59 PM
myisanog's Avatar
it was slipping so bad it was ridiculous . i was trying to drive up a big hill and the car jerked about halfway up and then it stalled out
Old May 24, 2010 | 03:35 PM
myisanog's Avatar
ok so i just drained and filled again .. and it doesnt seem like it has got any better . the fluid level is inbetween the max and min line now and it runs the same .
i was just taking it for a test drive and put it in d1 to see if it would run correctly and after 2000 rpm it would just over rev and no longer pull the car . and when i put it in D4, when in 2nd gear it would downshift occasionally which causes it to overrev and go no where .
Old May 24, 2010 | 09:22 PM
make sure of this before anything. It has to be 100% aligned with the hole and will sit in the hole with only the rubber oring without any bolts holding onto it. make sure it still sits snug when you tighten the 3 bolts holding the screen on.
Old May 25, 2010 | 01:27 AM
myisanog's Avatar
k i guess ill have to try that . i think when i put the screen on i was holding it up to put the screws in . will do it tomorow and will let u guys know what happens
Old May 28, 2010 | 02:54 PM
myisanog's Avatar
refitted the screen yesterday . no changes . tranny is slippin .
Old May 28, 2010 | 05:28 PM
TexasHonda's Avatar
did you put an oring on the tube of the inlet screen?
good luck
Old May 29, 2010 | 02:24 AM
myisanog's Avatar
yes o ring was on .
Old May 29, 2010 | 07:17 AM
TexasHonda's Avatar
You should check the hydraulic pump pressure (taps on external trans where pump pressure is measured), but I suspect you'll find it's very low.
Only reason I can think for such a sudden failure is somehow fluid is not being picked up. Did oring fit snugly into the inlet pipe? It should have an interference fit to seal. Perhaps a defective inlet screen?
good luck
Old May 29, 2010 | 11:10 AM
myisanog's Avatar
maybe .
i found out yesterday from a buyer that the cluster's miles were rolled back in 2007 since it had 207k in 07 . my brother bought the car in 09 and cluster reads 138k so im guessing it shuold be around 250kish miles . so tranny failure doesnt seem that out of the blue anymore
Old May 29, 2010 | 12:14 PM
TLin401's Avatar
'13 Hyundai Sonata
Wow that is f'd up and could end up in a lawsuit.
Old May 29, 2010 | 02:25 PM
yea, I don't see how a filter simple filter change could cause something like that if it was done correctly.
Old May 29, 2010 | 09:37 PM
myisanog's Avatar
hah well alls done thats done . im going to get the previous owner's info from the dmv sometime later this week and tell them to pay up or go to court .
and also i asked the local shop that wanted to buy my car how much the car is worth (since they werent going to buy it anymore since it has about 250k miles) and they told me around 1200 since transmission is failing . im not gona sell it for that low so im gona just keep it and look for a new tranny since i have a friend who says he'll do it for dirt, will save up for a new motor while im at it just in case this one starts going bad
acuratl26
Apr 23, 2020 07:30 PM
ttimberlak443
21
Oct 22, 2016 10:23 PM
BrownBuck
NY/NJ
Sep 29, 2015 09:53 PM
rangomango
California
Sep 24, 2015 05:47 PM
Hines57
Sep 24, 2015 01:58 PM
