Check Engine Light - Self Diagnostic?
Old Dec 25, 2013 | 12:09 PM
ootoaoo's Avatar
Is it possible to determine what the check engine light issue is on my 2001 TL without going to AutoZone?
I also have a 95 Maxima and I can turn the key a few ways then count the blinking lights. Is this possible with an Acura? It's my mother-in-law's car and I want to see what the problem is + see if it's fixable.
I googled a lot + searched here and only found threads on resetting the light.
Thanks in advance!
Old Dec 26, 2013 | 11:52 AM
Nicks2001tl's Avatar
Welcome to Acurazine!
There is no real way to check the engine codes without a scanner. What`s going on? Is the car not moving?
Old Dec 27, 2013 | 09:28 AM
fsttyms1's Avatar
You can jump pins 8 and 13 to get the code then you will have to look online what that code means (it will be different than your typical scanner code)
Code readers are pretty cheap now days, you can get bluetooth adapters for 20 bucks and free apps for smart phones or look on amazon or go to harbor freight, they also range from 20 bucks and up.
Old Dec 27, 2013 | 10:45 AM
nats007's Avatar
This... After reading this post, I just bought an ELM327 bluetooth OBD II scanner off amazon for $11. I'll pair it with the Torque app on my android and will be set for code reading
Old Dec 27, 2013 | 11:16 AM
3.2TLc's Avatar
Yeah, a scanner or code reader is well worth the money spent, IMO. The old school flash method is rather iffy and can easily be misread as the wrong code. An alternative would be to just drive the car to most any local auto parts store, as they will normally read the codes for free.
MikeYutkin
Sep 10, 2015 10:13 PM
Bahamanurse1
Sep 10, 2015 10:05 PM
HeloDown
Sep 8, 2015 06:51 PM
bryan zaragoza
Sep 8, 2015 12:28 AM
whitesoxsfan12
Sep 7, 2015 04:07 PM
