change rotor and caliper(pad)
Old Oct 17, 2008 | 01:30 PM
sangjun's Avatar
8th Gear
Talking change rotor and caliper(pad)
Can I change roter and caliper?
If possible, could tell me about it?
Old Oct 17, 2008 | 01:31 PM
sangjun's Avatar
8th Gear
2g tl-s
Old Oct 17, 2008 | 02:29 PM
Rajca's Avatar
wham bam thank you ma'am
if u have some basic tools and follow the diy in the diy section you can do it. while at it also flush the system and then bleed it in all four corners. just search in the diy section.
if your going to be changing the front calipers, change them to the 95 legend ls coupe calipers, their dual piston instead of our single piston
Old Oct 17, 2008 | 03:05 PM
fsttyms1's Avatar
Rotor and pad, yes. If you have to ask if you can change it i wouldnt even contemplate touching the caliper.
There are DIY's on changing the rotors and pads.
Old Oct 17, 2008 | 03:52 PM
01tl4tl's Avatar
If you have to ask-
then its time to make friends with another ziner in your town, or a private honda-acura shop
Brakes are critical-- as they keep you out of trees and other car trunks~
Old Oct 17, 2008 | 06:06 PM
FirePR2002's Avatar
bringin lead
can it be done - yes. should you do it - no (based on the way you asked the question). like others have said - make friends or find a good honda-acura tech / shop to do the work for you. brakes are the most important component of the car.
Old Oct 21, 2008 | 10:27 AM
smartypants's Avatar
As other have said, if you're asking that specific question, you should be either ready to invest time in learning and researching or take it to a pro. Doing this job wrong can kill you and worse, innocent or people you care about.
smartypants.
Old Oct 21, 2008 | 10:06 PM
sbuswell's Avatar
I need 2 more gears
so no you can't do it yourself. Pay someone to do it for you or if you are brave and learn fast, try replacing your rotors and pads, but be prepared to call someone you know well for help.
Old Oct 22, 2008 | 06:49 AM
totaledTL's Avatar
Great advice- have a friend who's done it on standby-
Old Oct 22, 2008 | 10:55 AM
01tl4tl's Avatar
have the friend THERE
brakes are nothing to fool around with
Damage to paint from spilled fluid is the least of your worries
read the DIY and see if you feel confident
Aleax
Sep 11, 2015 11:31 AM
HOWELLiNC
Sep 10, 2015 01:39 PM
mav888
1G RDX (2007-2012)
Sep 8, 2015 11:49 AM
