CD Won't Eject in 6 CD Changer
Old Mar 14, 2008 | 03:44 PM
Musashi22's Avatar
5th Gear
I have a problem that started today on my 2003 TL. I tried to eject a CD, and its giving me an Er-E1 error everytime I try to eject the cd. I tried to turn it off, tried it again, but no go. Anyone know how to resolve this problem, or do I have to go to the dealership so they can rob me of $$$ to fix this?.....I wouldn't mind taking it apart if needed. Please Help!....I'm living on IPOD music for now....
Thanks in Advance!
Old Mar 14, 2008 | 10:21 PM
Iggy's Avatar
Thanks in Advance!
Hit eject..........Then with a credit card in hand slide it into the opening above the stuck disk and push down on the stuck disk. This all has to happen while the servo is trying to eject the disk(happens pretty quick). Otherwise a good sharp bat with your fist might work.
Iggy
Old Mar 17, 2008 | 01:00 PM
EL19's Avatar
^^^ agree...
Old Mar 17, 2008 | 02:14 PM
drjay029's Avatar
regulator - 03 TL-S ABP
I had the same problem with my 6 disc. Take a pen tip and lightly press the tip directly centered on the flap. Keep trying and it will work! This will not cause any damage at all.
Old Mar 18, 2008 | 12:58 AM
LV Gordo's Avatar
I had the same thing when i got mine used. I did the credit card thing, now i just do my iPod exclusively. Woot, first post.
Old Mar 18, 2008 | 07:28 PM
drjay029's Avatar
Who ever said that it is a terrible idea to have a tape deck in the TL.......ty for Ipods! LOL
Old Mar 18, 2008 | 07:40 PM
chrismeoli's Avatar
mine is stuck too, seems common - recall???
Old Mar 24, 2008 | 10:37 PM
Musashi22's Avatar
5th Gear
Thanks for the suggestion it worked. I think I'm going to eventually replace this unit...anybody have an ideas on what would make a nice replacement with ipod capabilities. I was searching earlier, but couldn't really find one that fits the TL just right. And is it possible to continue using the steering wheel controls?
Old Apr 8, 2008 | 02:19 AM
tempest's Avatar
Mine is doing pretty much the same thing. ER-E1 code, but there's no CD stuck in the slot. I was about to try and put a new one in when it happened.
I've tried the credit card method as well as a "forceful" pat to the acura logo, as someone in a different thread suggested.
Any other suggestions?!
Old Apr 9, 2008 | 10:21 PM
drjay029's Avatar
I mentioned the pen trick earlier but try this exactly......take a pen, press on the center of the flap and hold it. As you hold the pen, keep hitting your CD button even though it will change automatically to the radio, tape, etc. If this doesn't work, its TOAST LOL.
Old Apr 10, 2008 | 01:26 AM
tempest's Avatar
In the center of the flap? Not under or over it? Right on it?
Just don't want to break it any more than it's already broken!
Old Apr 12, 2008 | 05:39 PM
drjay029's Avatar
Yes directly on the flap with moderate pressure.......
Old Apr 13, 2008 | 02:17 PM
tempest's Avatar
Cool man. I'll try that this afternoon. I hope it works! Thanks.
Old Apr 15, 2008 | 07:02 AM
tempest's Avatar
Dude, this worked like a charm! It took about 3 seconds worth of work.
Thanks!
Old Apr 16, 2008 | 08:23 PM
drjay029's Avatar
SAWEEEET!!!! I do this it seems every week and it always works. Glad i could help.
Old Apr 21, 2008 | 09:16 PM
Sheraton's Avatar
I have the same issue; no CD in the changer but when I select CD or try to load one I get the Er-e1 code. I can't do the pen trick because my flap is stuck open. Any suggestions?
Also, on another note with the Bose stereo, my sub seems very loud. Too much thump. Is there a way to turn the sub down?
Old Apr 22, 2008 | 01:02 AM
tempest's Avatar
Dude, my flap was stuck open too.
Use the pen, gently push it down to the closed position. Then apply gentle pressure in the middle while hitting the CD button.
Old Apr 23, 2008 | 04:09 PM
Sheraton's Avatar
OK, so I got the flap closed. When I try the pen trick nothing happens. I just keep getting the er-e1 code.
I know the changer is empty but it shows all slots full. Any suggestions? Somebody previously suggessted that the system would eventually check all the slots anf figure out they are empty. So far though that hasn't happened.
Old Apr 24, 2008 | 06:28 PM
drjay029's Avatar
In your case, I think you now have a 6 SLOT TOASTER.
GWEEDOspeedo
Jan 15, 2016 10:39 PM
eastsideride
Oct 15, 2015 04:26 AM
ITSJESTER
4G TL Photograph Gallery
Oct 13, 2015 12:53 PM
xsilverhawkx
Sep 28, 2015 06:51 PM
mars
Sep 28, 2015 11:03 AM
