CD player won't eject
Old Nov 20, 2006 | 07:04 PM
jason0617's Avatar
Hey,
I've got an '03 TL-S with 54K. I purchased it somewhat recently, and it's Acura certified. I got a new CD over the weekend, and when I went to eject one of the CD's, the player acted like it was ignoring me. It didn't make a sound like it was ejecting, or anything, it just kept playing the CD like I never pressed the button.
I'm taking my car in to the dealer to get a couple of minor things checked out, and I called and asked to have this added to the list, but the service guy told me that because I have a burned CD in the player, that it will not be covered by the warranty, and could add up to several hundred dollars, and I may have to purchase a new HU, out of pocket. The radio and CD changer are specifically covered under the Acura certification, so I don't think this is accurate.
Anyway, they're advising me to "do something to get the CD's out on my own" so I don't encounter a repair bill. I don't feel comfortable doing this, mostly because if I go sticking stuff into the changer to try to get a CD out, I'm quite sure that THAT would void my warranty, and also because I feel like if a car is under warranty, I shouldn't be expected to mess with electronic stuff that's supposedly covered anyway...
Finally, on to my question: Does anyone know if having a burned CD in the car will void my warranty, and if so, what are my options?
Thanks,
Jason
Old Nov 21, 2006 | 12:47 PM
acurabum's Avatar
Try to remove one of the other 5 CD to see if it will eject...... if yes then try to eject the burned one to see if it will eject ....some time the burned CD will ejected but get stucked
at the medium of the feader ...just vibrate it a bit and pull it out .....
Burned CD stucked = may have label that make it thicker the spec....
Old Nov 22, 2006 | 10:31 AM
jason0617's Avatar
none of them will eject.
Old Nov 22, 2006 | 03:58 PM
acurabum's Avatar
Did you say before you introduce the burned CD in to the unit everything is fine ? .....
If yes then maybe try to pull the radio fuse for 10 second to reste the unit .......
Oh and remember to check if you have the Radio Code ....Ok
Old Nov 24, 2006 | 11:30 AM
jason0617's Avatar
Nope, that didn't work, so it's at the dealer now getting fixed, along with the brakes. At least they gave me an '07 TL to drive in the meantime.
Old Dec 1, 2006 | 01:12 PM
rackster's Avatar
The stock HU doesn't like burnable media, especially the light scribe CDs - use the thinnest nominal thickness you can.
Old Dec 1, 2006 | 02:31 PM
bonknhead's Avatar
I have the same problem with burned CDs in my 03 TL-S, as I put labels on them. I keep a pair of tweezers in the glove box that I use to grab those burned CDs when I press eject. If I don't time it just right, the CD goes back in the HU, and an error displays. Can't play any CDs at that point - only the radio.
Old Dec 18, 2006 | 10:44 PM
03TLtype-s's Avatar
Originally Posted by jason0617
Hey,
Thanks,
Jason
Mine did that once and i disconnected the battry and puched in the code for the radio and that fixed my problem. It wouldn't reconize the 6 cd one day and when i shut off the car and started it worked...GO figure LOL but it hasn't happened since
Old Dec 19, 2006 | 05:34 AM
Leo Type-S's Avatar
03' NBP TL-S
hmm weird.. i don't have any problems with burned cds in my tl-s
Old Dec 20, 2006 | 11:00 AM
Brand Newb's Avatar
I had that issue with my original factory HU, inconsistantcy with cd's not ejecting, then ejecting. So...I brought the cd player in and they fixed it by replacing the unit with a new one. They didnt give me any crap either considering I had 4 of the 6 cd's were burned cd's. They mailed the cd's back to me a few weeks later. I have only had the problem with my new cd player once and it was because of a burned cd that had a label on it.
Oh and if you have the accent trim on the cd player (fake wood trim), and they replace your HU they wont put the trim back on.
Old Dec 20, 2006 | 08:47 PM
TheAcAvenger's Avatar
This is really weird. I've been using the same brand burned cd's for years, and now ONE of them is giving me serious issues. I had that instance where it'd jam sometimes and not others, but my dumb a** accidently put it back in there today, and now its consistently jamming and throwing Er-E1.
Fool
Mar 10, 2016 08:42 PM
GWEEDOspeedo
Jan 15, 2016 10:39 PM
ITSJESTER
4G TL Photograph Gallery
Oct 13, 2015 12:53 PM
xsilverhawkx
Sep 28, 2015 06:51 PM
mars
Sep 28, 2015 11:03 AM
