CD Changer not workin?
Old Aug 27, 2005 | 11:40 PM
jsacuraTL's Avatar
I was just wondering if anyone else has had issues with there factory cd changer not working. i bought a 99 acura 3.2 tl w/ the navigation system. and the cd changer will not work. it will eject the magazine.
Old Sep 5, 2005 | 03:55 AM
chewi's Avatar
yes... i have a problem with my 03 tl-s in which the display shows...ERE1...= error 1?
and its now jammed or not reading the CD's. I can eject, or change to the next cd either...
anyone have a clue?
Old Sep 5, 2005 | 05:43 AM
03CoupeV6's Avatar
05 C230K & 09 135i 6MT
I'm assuming you're talking about a factory installed trunk-mounted disc changer since the 99-01 had single-disc in-dash players?
Old Sep 8, 2005 | 02:19 PM
david_22_33's Avatar
7th Gear
chewi, I've had problems getting burned cd's out of my changer before. If the door opens a try to use another cd to push down on the one stuck inside. I don't think it can't grab the burned cd's as well as comercial cd's. Pop out all the discs and you should be good to go. If this doesn't help, I hope you still have your waranty.
-david
'03 TL-S
Old Oct 27, 2005 | 04:38 AM
chewi's Avatar
-david
'03 TL-S
yes i still hve warranty....
ANYWAYS...
last few weeks my 6 disc cd changer has no more CD Changing problems for some reason.
The Way i think i Fixed it was.... As soon as I got it to move and start changing CD's, I Ejected all 6 of the CD's out...
Then I put them all back in.
After putting them all back in.... I gave the CD Changer a good EXERCISE hoping that The CD changer mechanism will run smoother and not get stuck again...
HOW to EXERCISE your CD Changer?????????
Well... I just kept working the CD Changer by changing from CD 2-4-3-5-1-6(random order) for about 5 mins...
From then on I never got my CD's stuck while changing from disc to disc. and of course NO MORE ERE-01 code...
I'm just glad its working fine and i hope it wont screw up on me again.
Hope this helps
Sep 21, 2015 08:44 AM
mgbe11
1/2G MDX (2001-2013)
Sep 15, 2015 07:53 PM
drewdeezy03
Sep 3, 2015 08:04 PM
Chris.Su
Aug 13, 2002 07:09 PM
