Catalytic Converter - Engine Light
Old Mar 24, 2008 | 07:26 PM
VancouverRay's Avatar
Need some advice if possible. My engine light came on about 1 month ago and Acura diagnosed it as a cat converter problem and $1100.00 to replace. I have a 99 TL with California emissions and live in BC Canada. They attempted to replace it with a new part but had ordered the wrong one and are reordering the correct part from the US. About a week after they tried to replace the part, the engine light has gone off. My question is, Is there a time limit to how long the engine light stays on, or was there possibly nothing wrong with my cat in the first place and possibly a misdiagnosis from Acura to start with? Any input would be appreciated as $1100.00 is a big sting!
Old Mar 24, 2008 | 10:33 PM
Gfaze's Avatar
S E L L
Do you know what codes they pulled from the ECM? Check your work order and list the codes with description if possible.
Old Mar 25, 2008 | 08:32 AM
fsttyms1's Avatar
Pull the clock backup fuse on the passengers side dash fuse panel (that will reset the ECU) If the light comes back on Find a small shop that can read codes or a auto parts store <- (most do it for free) and get the codes read and tell us what the code is. If not your good to go
Old Mar 25, 2008 | 09:17 AM
Thanks for getting back to me. The work order has a line that reads: "118692 Check and Find Code P0420 (Catalyst system efficiency below threshold) Check and find faulty cat need to replace cat."
Old Mar 25, 2008 | 12:12 PM
01tl4tl's Avatar
Do you have muffler shops up there? go have one run a test on the car- they drill a hole and test pressure and flow.
Its not that far to come across and get it done for a few hundred at a private shop
Bahamanurse1
Sep 10, 2015 10:05 PM
HeloDown
Sep 8, 2015 06:51 PM
bryan zaragoza
Sep 8, 2015 12:28 AM
whitesoxsfan12
Sep 7, 2015 04:07 PM
jpm3071
NY/NJ
Sep 7, 2015 08:25 AM
