Car just DIES!!
Old Oct 8, 2006 | 07:11 PM
Eisenhulk's Avatar
MUCH bigger than you!!
Car just DIES!!
Hey guys,
Over the past few months, my car (1999 TL) will just die. The radio will stay on, but the engine just shuts down, and so does the rest of the car. Afterwards, I'll put the car in park and I'll try to start it, but it won't. I have to try 5-10 times before it will start again. When I'm trying to start it, it will start for less than a second and immediately die again. I have replaced the battery, and I'm thinking it's either the start or the ignition switch.
Any help would be GREATLY appreciated. This is becoming a real pain in the arse.
EH
Old Oct 8, 2006 | 07:44 PM
honda_inspire99's Avatar
Skeet Skeet Skeet
Originally Posted by Eisenhulk
Hey guys,
EH
more than likely htats what it is so u should go get it fixed under warranty
Old Oct 8, 2006 | 08:03 PM
sbuswell's Avatar
I need 2 more gears
should like an ignition problem. go to the dealer and have them check it out. that sucks having your car die on you.
Old Oct 8, 2006 | 08:13 PM
Bob_F's Avatar
Do you have another Honda or Acura key on your keyring?
I had some stalling and starting problems with my 1999 TL that were eliminated after I took a Honda key off my keyring. The Honda key also had an an ignition immobilizer. Look for the flashing immobilizer key symbol when you have the stalling problem.
And the immobilizer keys themselves can also go bad if they get too hot or if they get wet. If you have a spare key, try using that one to see if the problem goes away.
Also, there was an ignition switch recall for the second generation TL models. Did you ever have that replaced? If not, your Acura dealer should install a new one for free.
Good Luck!
Bob
Old Oct 8, 2006 | 08:24 PM
INSPIRE 32V's Avatar
Glacier Frost Mica CL-S
does that recall apply to any 2nd gen tl with any amount of miles or is it under 100k
Old Oct 8, 2006 | 08:39 PM
Bob_F's Avatar
The mileage is not a factor for the recall.
But I'm not sure if it applies to all 2nd gen TL models. You can call Acura with your VIN number and they can tell you if the recall applies and also if your car has received the new ignition switch.
You can also find this online after registering your car on Acura.com.
For my 1999 TL I called to find that the previous owner had the replacement switch installed.
Bob
Old Oct 8, 2006 | 10:18 PM
Skeet Skeet Skeet
u have to call the dealership to see if your vin # falls under warranty
Feb 25, 2020 09:57 AM
james357
Feb 13, 2016 02:37 PM
gemz_acura
4G TL Problems & Fixes
15
Sep 26, 2015 06:12 PM
jordanboi
Sep 5, 2015 01:33 AM
