A/C stopped working outta nowhere...
So as of 4:30am this morning, the A/C was blowing ICE cold as usual, I start the car up around 2 this afternoon and its blowing hot air, brand new condensor fan is not turning on and I dont believe the compressor is either. I used a test light and checked if the non-popped fuse (replaced it still) for the Condensor fan was getting power, it was, but then i checked the harness for the fan itself, its not getting any power, hence thats why its not coming on. Now Ive not had a single problem with the a/c, Its been recharged by the dealer last year.., any ideas what might be causing this?
do you hear the compressor click when you turn on the a/c? Did you check the actual wiring harness for the condenser fan or did you try testing the actual condenser fan? Try testing the condenser fan by hooking it up to power (battery) and see if it turns on. If it does not, unfortunately you will need another condenser fan. If it does run, there's a short circuit somewhere. Also, check if there is a relay for the condenser fan and test that if you find one.
yeah, the fan is still good, its just not getting any power some reason.. and the compressor is not clickin when it comes on, and as far as the relay, i switched it with another that I know works, that didnt fix it... Ive haven't seen anything like this.. i dont know how it could have just shorted somewhere, never wrecked and serviced only at acura.. weirrrrd
Originally Posted by NineT9TL
actually I didn't do that, but I did sawp it out with the cooling fan relay that is exactly the same and does work, and it did'nt help surprizingly.
