brake problems
Old Jul 16, 2006 | 08:11 PM
Spectacura's Avatar
6th Gear
brake problems
My brake rotors were warped about three months ago and now warped again. I don't really know what's going on but I believe that my calipers are sticking on the front. It is only the front rotors but I can't seem to figure out how to check the calipers to see if they are sticking. When I stop, sometimes it feels like the caliper on one side or another feels loose but it is all tight and seems to be fine but I can't keep this up. Gettin expensive. Please help. Is there only the piston on the caliper that should be greased?
Old Jul 16, 2006 | 08:15 PM
GreeneggsandHam's Avatar
When your rotors were warped, you had resurfaced the rotors & replaced the brake pads with new ones? If yes, what type of pads did you put on there? Also, try bleeding your brakes.
Old Jul 16, 2006 | 09:34 PM
fsttyms1's Avatar
For 1 did they just simply resurface the rotors or give you new ones? Resurfacing the stock rotors is usless.
get a new set of aftermarket rotors and pads. A way to see if they are sticking is jack the front up put the car in neutral and spin the wheel if it moves freely its not sticking. I doubt your have a hung rotor, warped rotors is very common on these cars
Old Jul 17, 2006 | 02:53 PM
Edward'TLS's Avatar
6G TLX-S
Spectacura, if you have the warped rotors fixed at the dealership, they will warranty the repair for a period of time. So when the rotors warp again three months later, you should bring the car back for warranty claim.
mada51589
Jan 9, 2025 04:40 PM
udelslayer
1G RDX Problems & Fixes
May 6, 2016 12:27 PM
CheeseyPoofs McNut
Oct 11, 2015 11:25 AM
rklatzkin
Sep 23, 2015 04:08 PM
HOWELLiNC
Sep 10, 2015 01:39 PM
