A/C Blower Motor Constantly ON
Old Jan 27, 2011 | 12:59 PM
duy's Avatar
duy
The blower motor is constantly on high. I have to unplug the plug to the blower motor to turn it off. Temperature controls work fine. OFF button does not.
I did the DIY for the blower motor subharness thinking that the wires shorted and fused together causing the blower motor be to stuck on high, but that was not the problem. So I removed the updated subharness.
I searched and read through a few threads and there were 2 threads with similar problems, but no fix was posted. And most threads I found were about the blower motor not working.
Control Transistor? If it is bad, wouldn't that cause the blower to not work?
I'm stumped and can't figure out why the blower stays on constantly.
Any ideas?
Thanks.
Old Jan 27, 2011 | 03:23 PM
acutee's Avatar
Sounds like the OFF button controller stops working.
Old Jan 27, 2011 | 06:58 PM
duy's Avatar
duy
^^^Thanks.
Know how to test it, other then pushing the button?!
Old Jan 27, 2011 | 07:47 PM
totaledTL's Avatar
Maybe the transistor has shorted- take it out & test it.
Old Jan 28, 2011 | 11:00 AM
duy's Avatar
duy
^^^Thanks.
If the transistor shorted, could it cause the motor to stay on? I figured if it was bad, then no power should be getting to the motor.
Old Jan 28, 2011 | 11:56 AM
totaledTL's Avatar
Generally, yes.
Old Jan 28, 2011 | 11:31 PM
01tl4tl's Avatar
maybe the power connector under the blower is shorting itself to On?
been a lot of those melting recently
Old Jan 31, 2011 | 11:11 AM
duy's Avatar
duy
Originally Posted by totaledTL
Generally, yes.
Thanks!
It was the Control Transistor. Changed it and everything is working correctly.
Old Jan 31, 2011 | 12:59 PM
totaledTL's Avatar
Great- so it was shorted?
Old Jan 31, 2011 | 01:46 PM
duy's Avatar
duy
^^^Yes.
I didn't test it to be sure, but when I opened up the transistor the board had burned spots and a slight smell of melted plastic.
Thanks again for the help.
Old Jan 31, 2011 | 06:23 PM
01tl4tl's Avatar
did you ck the power connector for damage- melting- loose wires etc
that is what usually preceeds the transistor failure
Old Jan 31, 2011 | 06:41 PM
duy's Avatar
duy
I did and the plugs/wires looked fine. Since I do have the updated sub-harness, which I installed and un-installed, I'll re-install it again just to be safe.
Old Jan 31, 2011 | 09:04 PM
01tl4tl's Avatar
thats the best plan- its updated for a reason
Biggie_B
May 27, 2025 05:51 PM
08KBP_VA
Oct 22, 2019 01:55 PM
Sarlacc
Console & Computer Gaming
Sep 30, 2015 02:15 PM
hashbrown
Sep 29, 2015 12:13 PM
xsilverhawkx
Sep 28, 2015 06:51 PM
